EXTRACT TEXT
sna
Excel Ver: Excel 365
EXTRACT TEXT
Post by sna »
Hi Dear
I need your help how to write code to extract text from mixed number and text.
I have a code below.any one can help with simplified code
Sub MyMacro()
Sheets("Sheet1"). Select
'   Find last row in column D with data
    lr = Cells(Rows.Count, "D").End(xlUp).Row
'   Enter formulas
    Range("F2:F" & lr).FormulaR1C1 =  "=SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(RC[-2],1,""""),2,""""),3,""""),4,""""),5,""""),6,""""),7,""""),8,""""),9,""""),0,"""")"
As well as provide me with excel 365 formula as well.
Thanks
norkaz
Excel Ver: 2013,365
Re: EXTRACT TEXT
Post by norkaz »
Hi Guy
I'm not a VBA guy, if you could extract text by using the formula -- the O365 spill array formula like this might be a good choice.
F2
=BYROW(D2:D4,LAMBDA(q,IF(q="","",CONCAT(TEXTSPLIT(q,ROW(1:10)-1)))))
Norkaz
sna
Re: EXTRACT TEXT
Post by sna »
I come with this formula
=BYROW(D2:D4,LAMBDA(a,CONCAT(TEXTSPLIT(a,SEQUENCE(10,,0)))))
Thanks
norkaz
Excel Ver: 2013,365
Re: EXTRACT TEXT
Post by norkaz »
sna wrote: Wed Jun 14, 2023 2:40 pm I come with this formula
Thanks
Hi Guy,
Nice shot with SEQUENCE starting with 0 -- it would be better to take the IFERROR before CONCAT like this.
=BYROW(D2:D4,LAMBDA(a,IFERROR(CONCAT(TEXTSPLIT(a,SEQUENCE(10,,0))),"")))
and the MAP function can be replaced BYROW in this situation.
=MAP(D2:D4,LAMBDA(a,IFERROR(CONCAT(TEXTSPLIT(a,SEQUENCE(10,,0))),"")))
Norkaz
sna
Re: EXTRACT TEXT
Post by sna »
tks Norkaz.it's really such a helpful formula
