Sum conditional
sna
Excel Ver: Excel 365
Sum conditional
Post by sna »
NEED HELP #EXCEL #formulas
To get total of numbers on left column of items mentioned of party / buyers.
please check the attached file for further reference req if any one can help.
Tks
Re: Sum conditional
:D Please provide an example of the correct answer and explain how to think so it will be easier to understand.
sna
Re: Sum conditional
Post by sna »
Thanks for your response
the criteria and expected results are in the sheet.
Tks
Re: Sum conditional
:D The example formula in B11 is below.
=SUMPRODUCT(SUBTOTAL(9,OFFSET($B$2,ROW($B$2:$B$7)-ROW($B$2),3*(COLUMN($B$1:$H$1)-COLUMN($B$1))))*($A$2:$A$7=$A11)*(SUBSTITUTE(B$10,"TOTAL ","")=T(OFFSET($C$2,ROW($B$2:$B$7)-ROW($B$2),3*(COLUMN($B$1:$H$1)-COLUMN($B$1))))))
Enter and copy to the right then down.
sna
Re: Sum conditional
Post by sna »
Thanks it is working
