Sub test()
Dim lr As long ,s As String,X As Long
lr=Sheet1.Cells(Sheet1.Rows.Count,1).End(xlUp).Row+1
s=Sheet1.Range("B2").Text
X=Application.Match(s,Sheet1.Range("A:A"),0)
Sheet1.Range("D"& X).Value=Sheet1.Range("C2").Value
Msgbox "data saved!"
[B2:C2].Clearcontents
Sub Trust()
Dim LastRow As Long, S As String, fRng As Long
Dim r As Range
LastRow = Cells(Rows.Count, 1).End(xlUp).Row + 1
S = Sheet1.Range("B2").Text
' fRng = Application.WorksheetFunction.Match(S, Sheet1.Range("A:A"), 0)
For Each r In Range("b5:b" & LastRow)
If r.Value & r.Offset(0, 1).Value = Range("b2").Value Then
' Range("D" & fRng) = Sheet1.Range("C2").Value
r.Offset(0, 2).Value = Sheet1.Range("c2").Value
Exit For
MsgBox "DATA SAVED"
Range("B2:C2").ClearContents
