Sub loopAllSubFolderSelectStartDirectory()
Call LoopAllSubFolders("D:\แยกรายภาค\")
Sub LoopAllSubFolders(ByVal folderPath As String)
Dim fileName As String
Dim fullFilePath As String
Dim numFolders As Long
Dim folders() As String
Dim i As Long
Dim strThisOne As String
Dim strFile As String
Dim wbk As Workbook
If Right(folderPath, 1) <> "\" Then folderPath = folderPath & "\"
fileName = Dir(folderPath & "*.*", vbDirectory)
While Len(fileName) <> 0
If Left(fileName, 1) <> "." Then
fullFilePath = folderPath & fileName
If (GetAttr(fullFilePath) And vbDirectory) = vbDirectory Then
ReDim Preserve folders(0 To numFolders) As String
folders(numFolders) = fullFilePath
numFolders = numFolders + 1
Set Wkb = Workbooks.Open(fileName:=folderPath & fileName)
ActiveWorkbook.ActiveSheet.Copy After:=Workbooks("รวม.xlsm").Sheets(Workbooks("รวม.xlsm").Sheets.Count)
ActiveWorkbook.Close
fileName = Dir()
Wend
For i = 0 To numFolders - 1
LoopAllSubFolders folders(i)
Call SaveMyWorkbook
Call Delete_Sheets
Sub SaveMyWorkbook()
Dim str As String
Dim str1 As String
Dim str2 As String
Dim wbk As Workbook
Dim Name As String
Set wbk = ActiveWorkbook
strThisOne = wbk.FullName
Name = ActiveSheet.Name
str = Right(Name, Len(Name) - InStr(Name, "ภาค") + 1)
strFile = "D:\แยกรายภาค\" & str & ".xlsx"
wbk.Save
wbk.SaveAs fileName:=strFile, FileFormat:=xlOpenXMLWorkbook
'Workbooks.Open strThisOne
Call Delete_Sheets
Sub Delete_Sheets()
Dim i As Long
For i = Worksheets.Count To 2 Step -1
Worksheets(i).Delete
Sub Example()
Dim FileSystem As Object
Dim HostFolder As String
Dim subFolder As Object
Dim fPath As String
Dim file As Object
Dim twb As Workbook
Dim wb As Workbook
Dim sh As Worksheet, scSh As Worksheet
Dim tgS As Worksheet
HostFolder = "D:\แยกรายภาค"
fPath = "D:\สรุปภาค\"
Set FileSystem = CreateObject("Scripting.FileSystemObject")
For Each subFolder In FileSystem.getfolder(HostFolder).subfolders
Select Case subFolder.Name
Case "ภาค 1"
Set twb = Workbooks.Open(fPath & "ภาค 1.xlsx")
Case "ภาค 5"
Set twb = Workbooks.Open(fPath & "ภาค 5.xlsx")
Case "ภาค 10"
Set twb = Workbooks.Open(fPath & "ภาค 10.xlsx")
Case "ภาค 11"
Set twb = Workbooks.Open(fPath & "ภาค 11.xlsx")
End Select
For Each file In subFolder.Files
Set wb = Workbooks.Open(file)
For Each sh In wb.Worksheets
For Each scSh In twb.Worksheets
If scSh.Name = sh.Name Then
scSh.Cells.Copy sh.Range("a1")
Next scSh
Next sh
wb.Close False
Next file
twb.Close True
Next subfolder
End Subb
