Public Sub NonRecursiveMethod()
Dim fso, oFolder, oSubfolder, oFile, queue As Collection
Set fso = CreateObject("Scripting.FileSystemObject")
Set queue = New Collection
queue.Add fso.GetFolder("D:\Detail\wetransfer_2022-1-zip_2022-10-25_1306\")
Do While queue.Count > 0
Set oFolder = queue(1)
queue.Remove 1 'dequeue
For Each oSubfolder In oFolder.SubFolders
queue.Add oSubfolder 'enqueue
Next oSubfolder
For Each oFile In oFolder.Files
oFile = Dir("*FINAL COST*")
Do While Len(oFile) > 0
Debug.Print
Next oFile
Sub sample2()
Dim FileSystem As Object
Dim HostFolder As String
HostFolder = "D:\Detail\wetransfer_2022-1-zip_2022-10-25_1306\"
Set FileSystem = CreateObject("Scripting.FileSystemObject")
DoFolder2 FileSystem.GetFolder(HostFolder)
Sub DoFolder2(Folder)
Dim SubFolder
For Each SubFolder In Folder.SubFolders
If found Then Exit For
DoFolder2 SubFolder
Next
Dim File
Dim n As Long
For Each File In Folder.Files
'for each InFile in Folder.File
If Left(File.Name, 10) = "FINAL COST" Then
found = True
n = Range("A" & Rows.Count).End(xlUp).Row
Sheets("Sheet1").Range("B" & n + 1) = Folder.Name
Sheets("Sheet1").Range("A" & n + 1) = File.Name
'Next
Next
Dim SubFolder, File
Dim n As Long
DoFolder2 SubFolder
Next
Next
Sub sample2()
Dim SubFolder
DoFolder2 SubFolder
Next
Dim File
Dim n As Long
Dim n2 As Long
Dim sh As Worksheet
Dim tws As Workbook
found = True
n = Sheets("List").Range("A" & Rows.Count).End(xlUp).Row
n2 = Sheets("Detail1").Range("C" & Rows.Count).End(xlUp).Row
Sheets("List").Range("B" & n + 1) = Folder.Name
Sheets("List").Range("A" & n + 1) = File.Name
'myfile = Dir(File)
' ws = File.Workbook
For Each sh In tws
If Left(sh.Name, 10) = "FINAL COST" Then
Sheets("Detail1").Range("C" & n2 + 1) = Range("A12:AW12").Value
Next
' With Workbooks(File)
' If Left(sh.Name, 10) = "FINAL COST" Then
' Sheets("Detail1").Range("C" & n2 + 1) = Range("A12:AW12").Value
' End If
' End With
Next
Sub sample2()
Dim SubFolder
Dim File
Dim n As Long
Dim n2 As Long
Dim sh As Worksheet
Dim tws As Workbook
DoFolder2 SubFolder
Next
Call GetSheetname(theFullName:=File)
Next
Sub ImportFile(sFile As String, sh As String)
Dim sCnstr As New ADODB.Connection
Dim rs As New ADODB.Recordset
Dim sql As String, shtName As String
shtName = "[" & VBA.Replace(sh, "'", "") & "]"
sql = "select * from " & shtName
sCnstr.Open "Provider=Microsoft.ACE.OLEDB.12.0;" _
& "Data Source=" & sFile & ";" _
& "Extended Properties=""Excel 12.0 Xml;HDR=YES"";"
rs.Open sql, sCnstr
With Worksheets("Sheet1")
.Range("A" & Rows.Count).End(xlUp).Offset(1, 0) _
.CopyFromRecordset rs
Set sCnstr = Nothing
Set rs = Nothing
Function GetSheetname(ByVal theFullName As String) As String
Dim cn As ADODB.Connection
Dim rsT As ADODB.Recordset
Dim intTblCnt As Integer
Dim strTbl As String
Dim t As Integer
Set cn = New ADODB.Connection
cn.Open "Provider=Microsoft.ACE.OLEDB.12.0;" _
& "Data Source=" & theFullName & ";" _
& "Extended Properties=""Excel 12.0 Xml;HDR=NO"";"
Set rsT = cn.OpenSchema(adSchemaTables)
intTblCnt = rsT.RecordCount
Do While Not rsT.EOF
strTbl = rsT.Fields("TABLE_NAME").Value
If Right(strTbl, 2) = "$'" And VBA.Left(strTbl, 11) = "'COST SHEET" Then
Call ImportFile(sFile:=theFullName, sh:=strTbl)
rsT.MoveNext
rsT.Close
cn.Close
End Function
Sub sample2()
Dim SubFolder
Dim File
Dim n As Long
Dim n2 As Long
Dim sh As Worksheet
Dim tws As Workbook
DoFolder2 SubFolder
Next
Next
rs.Open sql, sCnstr
Set rs = Nothing
Dim t As Integer
rsT.MoveNext
rsT.Close
cn.Close
End Function
