vba sum
sna
Excel Ver: Excel 365
vba sum
Post by sna »
Hello code experts
If you press the button in the conditions sheet, a new sheet is created by the name of portal.
In this workbook, the 2B sheet containing the same Invoice Number have different amount values in column J K L M and N. The amount values of J K L and M are combined in one row and displayed in Portal sheet. I want to combine the values of column N also and display in the Portal sheet. For that, I need your expertise and help to to edit the code to get the combined value of N in the portal sheet.
Tks
Get cess sum 2B.xlsm
(46.89 KiB) Downloaded 88 times
Re: vba sum
:D Change this statement
dic(id) = s(0) & "|" & s(1) & "|" & s(2) & "|" & s(3) & "|" & s(4) & "|" & _
        s(5) & "+" & cell.Offset(0, 8) & "|" & s(6) + cell.Offset(0, 9) & "|" & _
        s(7) + cell.Offset(0, 10) & "|" & s(8) + cell.Offset(0, 11) & "|" & _
        s(9) + cell.Offset(0, 12) & "|" & s(10) & "|" & s(11) & "|" & _
        s(12) & "|" & s(13) & "|" & s(14) & "|"
to
        s(9) + cell.Offset(0, 12) & "|" & s(10) + cell.Offset(0, 13) & "|" & s(11) & "|" & _
sna
Re: vba sum
Post by sna »
thank you ☺️
