format HH:mm:ss
sna
Excel Ver: Excel 365
format HH:mm:ss
Post by sna »
Hi there!
hope you're all doing great.
I come here again for seeking a help to convert text string in Days Hours Mins into HH:mm:ss format.
I attach a template
Thanks
Re: format HH:mm:ss
:D Try this formula.
B2
=(TRIM(MID(SUBSTITUTE(A2," ",REPT(" ",50)),1,50))*VLOOKUP(TRIM(MID(SUBSTITUTE(A2," ",REPT(" ",50)),51,50)),{"Days",1440;"Week",10080;"Hours",60;"Mins",1},2,0)+TRIM(MID(SUBSTITUTE(A2," ",REPT(" ",50)),101,50))*VLOOKUP(TRIM(MID(SUBSTITUTE(A2," ",REPT(" ",50)),151,50)),{"Days",1440;"Week",10080;"Hours",60;"Mins",1},2,0))/60/24
Enter and copy down and custom format cells with [h]:mm:ss.
sna
Re: format HH:mm:ss
Post by sna »
Thank you so much,I will take a look
