cal.work hours
sna
Excel Ver: Excel 365
cal.work hours
Post by sna »
Hi Dear
I need your help how to calculate difference between two dates and time (21:00-7:00)
The time between 21:00-07:00 is the night working time. How can the C column formula be in this case?
I attached a sample
Thanks
sna
Re: cal.work hours
Post by sna »
Still got no answer yet
Re: cal.work hours
:D Try these formulas,
  1. D1:H1 fill Start, End, Part1, Part2 and Total respectively
  2. D2
    =MOD(A2,1)
    Enter > Copy down
  3. E2
    =MOD(B2,1)
    Enter > Copy down
  4. F2
    =IF(D2=0,IF(E2<=7/24,E2),MAX(0,7/24-D2))
    Enter > Copy down
  5. G2
    =IF(D2>=21/24,MAX(0,E2-D2+(E2<D2)),IF(AND(D2<=21/24,E2>=21/24),E2-21/24))+INT(B2-A2)*10/24
    Enter > Copy down
  6. H2
    =F2+G2
    Enter > Copy down
sna
Re: cal.work hours
Post by sna »
Thank you so much 🙏
Bo_ry
Excel Ver: MS 365
Re: cal.work hours
Post by Bo_ry »
D2
=((DAYS(B2-21/24,A2-21/24)+1)*10-MIN(10,MOD(A2*24-21,24))-MAX(0,10-MOD(B2*24-21,24)))/24
sna
Re: cal.work hours
Post by sna »
Thank Bo_ry for a nice solution as well
