vertical output
sna
Excel Ver: Excel 365
vertical output
Post by sna »
Hi Dear
I have name and value in column a and b.
i need to transfer value greater than 20 by column wise.
I attached a template with result in color cells
Thanks
norkaz
Excel Ver: 2013,365
Re: vertical output
Post by norkaz »
D2
=IFERROR(INDEX($A$1:$B$20,AGGREGATE(15,6,ROW($B$2:$B$20)/($B$2:$B$20>20),INT(COLUMNS($D$2:E2)/2)),MOD(COLUMNS($D$2:E2),2)+1),"")
Norkaz
sna
Re: vertical output
Post by sna »
Thank you
