replace texts
sna
Excel Ver: Excel 365
replace texts
Post by sna »
Hi Dear!
I need your help to replace texts within the range.
I also place the expected results in adjacent column.
Thank
norkaz
Excel Ver: 2013,365
Re: replace texts
Post by norkaz »
B2
=SUBSTITUTE(A2,LOOKUP(99,SEARCH($D$2:$D$6,A2),$D$2:$D$6),LOOKUP(99,SEARCH($D$2:$D$6,A2),$E$2:$E$6))
Norkaz
sna
Re: replace texts
Post by sna »
Thanks.I want to ask is it possible to do formula Substitute with index ?
norkaz
Excel Ver: 2013,365
Re: replace texts
Post by norkaz »
B2
=SUBSTITUTE(A2,INDEX($D$1:$D$6,AGGREGATE(14,6,ROW($D$2:$D$6)/ISNUMBER(SEARCH($D$2:$D$6,A2)),1)),INDEX($E$1:$E$6,AGGREGATE(14,6,ROW($D$2:$D$6)/ISNUMBER(SEARCH($D$2:$D$6,A2)),1)))
Norkaz
sna
Re: replace texts
Post by sna »
Thanks
