sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Wed Oct 07, 2020 6:27 pm
Hi Dear
I have an issue I need to copy data from sheet Reconcile Txn to Backup Sheet but not empty.
what should I add or edit my code to do that?
sna
by sna » Wed Oct 07, 2020 6:29 pm
Please refer to this template .I also need your help how to clear data more dynamic(Module 1 and 2)
Thanks
Posts: 31271 Joined: Sun Jan 24, 2010 12:33 pm
by snasui » Wed Oct 07, 2020 8:43 pm
The example code is below:
Sub CL()
'RCL2.[A6:Y100].ClearContents
With RCL2
.Range("a6:y" & .Range("a" & .Rows.Count).End(xlUp).Row).ClearContents
sna
by sna » Wed Oct 07, 2020 10:27 pm
thank how about copy and paste without blank rows in Module 3?
by snasui » Wed Oct 07, 2020 10:52 pm
With RCL1
r = [Sumproduct(--('RECONCILE TXN'!b12:b100<>""))]
.Range("b12:z12").Resize(r).Copy
RCL4.Range("a1").PasteSpecial xlPasteValues
sna
by sna » Thu Oct 08, 2020 7:55 am
Thank you
sna
by sna » Thu Oct 08, 2020 8:52 pm
If Intersect(Target, Range("B:B")) Is Nothing Then Exit Sub
Range("B" & Target.Row).Resize(, 20).Copy Sheets("Sheet2").Cells(Rows.Count, "A").End(xlUp).Offset(1, 0)
your code work fine,is it possible like this??
or we can use special cell constant?
Thank you once again
by snasui » Fri Oct 09, 2020 6:28 am
It possible to do everything with code. Try with yourself for your task, post the error and attach file to here.
sna
by sna » Fri Oct 09, 2020 7:32 am
Thank you
sna
by sna » Fri Oct 09, 2020 12:11 pm
I test
Range("B" & Target.Row).Resize(1, 20).Copy RCL4.Cells(Rows.Count, "A").End(xlUp).Offset(1, 0)
it is not working !
by snasui » Sat Oct 10, 2020 6:58 am
You need to post code with code style such as post #7.
Attach the updated file that have your latest code inside and explain what you want to do and point to the expected result from your code.
sna
by sna » Sat Oct 10, 2020 8:37 am
Range("B" & Target.Row).Resize(, 20).Copy RCL4.Cells(Rows.Count, "A").End(xlUp).Offset(1, 0)
I need to copy from RCL1 to RCL4 without empty cells
Best wishes
by snasui » Sat Oct 10, 2020 9:30 am
snasui wrote: Sat Oct 10, 2020 6:58 am
Please read my post above carefully.
sna
by sna » Sat Oct 10, 2020 11:50 am
Here's the attached file for your reference
Thanks
by snasui » Sat Oct 10, 2020 2:11 pm
You can call 'CopyNonBlankValue' as below.
' Range("B" & Target.Row).Resize(, 24).Copy RCL4.Cells(Rows.Count).End(xlUp).Offset(1)
Call Module3.CopyNonBlankValue
sna
by sna » Sat Oct 10, 2020 4:30 pm
Ok.thank will update you
