comparative
Re: comparative
#21
:D Please attach the updated file and point to cell that shown incorrect result and fill in the correct value for that cell for easy to understand it.
sna
Excel Ver: Excel 365
Re: comparative
#22
Post by sna »
Thanks for your kind ,I just highlighted the non matching value
Re: comparative
#23
snasui wrote: Sat Sep 26, 2020 7:37 am :D Adjust your formulas as below:
Q13
=IFERROR(INDEX('T24 INTRA'!N:N,MATCH(E13,'T24 INTRA'!$G:$G,0))+0,"")
Enter > Copy down
:D Please update column Q with my formula on above.
For the latest file in post #22, could you please explain how do you know the value in I23 and T23 is the same?
What the condition for convert the value in I13 (or T23)?
For now I think the formula in cell AB13 is:
=AND(F13=Q13,G13=R13,H13=S13,OR(I13=T13,I13*100=T13),J13=U13,ISNUMBER(SEARCH(V13*IF(R13="USD",4000,1),K13)),L13=W13,LEFT(M13,10)=LEFT(X13,10))
sna
Re: comparative
#24
Post by sna »
Hi Dear thank you but I have currency KHR,USD,THB
1USD=4000KHR,1THB=129.55 KHR
Re: comparative
#25
:D You can adjust this part:
...V13*IF(R13="USD",4000,1)...
please try with yourself first.
sna
Re: comparative
#26
Post by sna »
Ok thank you 🙏
sna
Re: comparative
#27
Post by sna »
I check it error date and rate base on my formula in intranet column AH and AJ.
What's wrong with the formula?
Re: comparative
#28
:D Please point to the error, provide the correct result, all condition you use and attach file again.
sna
Re: comparative
#29
Post by sna »
Here is attached file I check in sheet Reconcile Txn
Re: comparative
#30
:D Please read my post (#28) carefully.
sna
Re: comparative
#31
Post by sna »
I put the test result in ReconcileTxn in column A
Re: comparative
#32
:D You can add +0 for convert date as text to date as number in old formula in column 'E' as below:
=IFERROR(INDEX(INTRANET!AH:AH,MATCH(ROW()-12,INTRANET!$AG:$AG,0))+0,"")
Enter > Copy down.
sna
Re: comparative
#33
Post by sna »
Thank you
sna
Re: comparative
#34
Post by sna »
No luck ,see attached file
Re: comparative
#35
:D Please check regional and language on your machine, the format of date must be dd/mm/yyyy not mm/dd/yyyy.
Or change the formula on C13 with this,
=IFERROR(TEXT(INDEX(INTRANET!AH:AH,MATCH(ROW()-12,INTRANET!$AG:$AG,0)),"m/d/yy")+0,"")
Enter > Copy down.
sna
Re: comparative
#36
Post by sna »
Thank you 🙏
