loop thru folder
sna
Excel Ver: Excel 365
loop thru folder
Post by sna »
Hi Dear,
I got some issue with loop thru folder to copy excel files and place it in a sheet continuously.
I have many excel files download from a system and place it a folder saved name as daily like 01-09-2020...etc
Here is my template
Best Wishes,
sna
Re: loop thru folder
Post by sna »
Here's the attached
sna
Post by sna »
Attached
:D The attach file must less than 500 kb.
sna
Post by sna »
Here's the attached
:D You can add procedure for loop all path in your computer with these step:
  1. Add one sheet and named PathAll
  2. Add procedure named LoopAllPath
  3. Modify old procedure for receive variable from LoopAllPath
See picture below.
sna
Post by sna »
Thanks
sna
Post by sna »
Thank will try it
