sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Thu May 07, 2020 4:26 pm
Hi Dear
I need your assistance for quote price.
I have a sheet call quotation price sheet.
I need formula to give a tick mark if the unit price among three is lower otherwise untick mark.Total column cell upon the tick mark cell.
For example
G13:$7
I13:$10
K13:$8
So F13 tick mark
H13 untick mark
J13 untick mark
and so on
Also refer to attached file
Hope you may help
Best wishes
Posts: 31271 Joined: Sun Jan 24, 2010 12:33 pm
by snasui » Thu May 07, 2020 11:32 pm
Try this,
F13
=CHAR(IF(COUNTIF($E13:E13,G13),163,IF(G13=MIN($G13,$I13,$K13),82,163)))
Enter and copy formula down and copy F13:F18 paste to H13:H18, J13:J18 respectively.
sna
by sna » Fri May 08, 2020 5:52 am
Hi Dear
much appreciated.it works flawlessly.
How about in L2 if unit price is lower then multiply that unit price with quality
Best wishes,
by snasui » Fri May 08, 2020 7:08 am
The formula in L13 should be
=MIN(G13:K13)*D13
Press enter and copy down.
In G20 should be
=SUMPRODUCT(--(CODE(F13:F18)=82),$D13:$D18,G13:G18)
Press enter and copy to I20 and K20.
sna
by sna » Fri May 08, 2020 11:00 am
Hi Dear
Thank you so much.it works
Best wishes,
