กำหนดค่า Drop Down List ใน Data Validation ที่Sheet อื่น
impresxy
Post by impresxy »
Data Validation ใน Excel 2010 ไม่สามารถกำหนดค่าใน Drop Down List ที่ Sheet อื่นได้เหรอคะ ทำตอนแรกได้ค่ะ แต่พอ Save แล้วเปิดใหม่ มันก็ไม่มี Drop Down List แล้วค่ะ
ขอบคุณมากค่ะ
Re: กำหนดค่า Drop Down List ใน Data Validation ที่Sheet อื่น
:D ขอดูไฟล์หน่อยได้ไหมครับ
impresxy
Post by impresxy »
Collumn E in WPQR Sheet ka.. Try to get the List from Sheet 1 ka..
:D I found that it shown properly in my computer see picture below.
impresxy
Post by impresxy »
So sorry ka Archan, but mine is not like what you are showing. After I saved the file and reopen, I have to make the Data Validation again to retrieve the list from the other sheet. Unlike when I have all in the same sheet, there won't be any problem ka.. Thank you anyway na ka.. I will put them in the same sheet ka.. T_T
impresxy
Post by impresxy »
Please see the picture ka.. There is nothing in the drop down list at all ka..
impresxy wrote:Please see the picture ka.. There is nothing in the drop down list at all ka..
I saw that the title of your file shown "Compatibility Mode". That means you have saved in 2003- format and can't use validation in other sheet. Only Excel 2010 can use validation on other sheet.
impresxy
Post by impresxy »
:lol: :lol: :lol: :lol:
OKkkkkkkkk...!!! I will try to copy all to the new one ka.. Thank you so much na ka..
It because I got the file from someone else to continue the records and I just saved without changing the version ka...
Thank you so much ka Archan ... >_<
