extract text
sna
Excel Ver: Excel 365
extract text
Post by sna »
Hi there
I need your help how to extract text from cell containing Widget.
I attach a template as well
Thanks
Re: extract text
:D In C2 enter this formula,
=FILTERXML("<k><m>"&SUBSTITUTE(SUBSTITUTE(A2,"_"," ")," ","</m><m>")&"</m></k>","//m[contains(.,'Widge')]")
or
=TRIM(LEFT(SUBSTITUTE(MID(A4,AGGREGATE(15,6,SEARCH({"Econo","Ultra","Thermo","|"},A4&"|"),1),20)," ",REPT(" ",20)),20))
Enter and copy down.
sna
Re: extract text
Post by sna »
Thank you so much 🥰
sna
Re: extract text
Post by sna »
I got a problem bec the results not like the color cells in next column
Thanks
norkaz
Excel Ver: 2013,365
Re: extract text
Post by norkaz »
B2
=IFERROR(INDEX({"WELVU","ECONO","ULTRA","BC","DENDR","THERMO"},MATCH(TRUE,SEARCH({"WELVU","ECONO","ULTRA","BC","DENDR","THERMO"},A2)>0,0)),"")
Norkaz
sna
Re: extract text
Post by sna »
Thanks
