lag one row every dups
sna
Excel Ver: Excel 365
Post by sna »
Hi there,
I can create a helper column then sort to insert one row below each dups.here I want a formula to skip one row every each dups.
TY
I attach a sample as well
Re: lag one row every dups
:D Try this
Cell B2
=IFERROR(IF(COUNTIF($A$2:$A$15,B1)=COUNTIF(B$1:B1,B1),"",INDEX($A$2:$A$15,ROWS($B$2:B2)-COUNTIF(B$1:B1,""))),"")
Enter and copy down.
sna
Post by sna »
Thank you 😊
