Code issue
sna
Excel Ver: Excel 365
Code issue
Post by sna »
Hi Dear
I need your help what's wrong with this code ,
I got seasick with it.
My problem is here with this code, I guess:
ActiveWorkbook.Worksheets("CumulativeData").Cells(Rows.Count, 1).End(xlUp).Offset(1, 0).Select
ActiveSheet.Paste
When I run this, it pastes the data from Results worksheet for first run but but creates row number 1 blank from second run. I want my data from row 1 with no header row. Any help with this is highly appreciated.
Sub Import_data()
    Dim FileToOpen As Variant
    Dim OpenBook As Workbook
    Dim destinationRow As Integer
FileToOpen = Application.GetOpenFilename(Title:="Browse for your File & Import Range", FileFilter:="Excel CSV Files (*.csv*),*csv*")
  If FileToOpen <> False Then
    Set OpenBook = Application.Workbooks.Open(FileToOpen)
    OpenBook.ActiveSheet.Range("A11:R11,A33:R33").Copy
    ThisWorkbook.Worksheets("Results").Range("A13").PasteSpecial xlPasteValues
    OpenBook.Application.CutCopyMode = False
    OpenBook.Close False
    Range("A13:A14").Select
    Range(Selection, Selection.End(xlToRight)).Select
    Selection.Copy
    ActiveWorkbook.Worksheets("CumulativeData").Select
    destinationRow = ActiveWorkbook.Worksheets("CumulativeData").Cells(Rows.Count, 1).End(xlUp).Offset(1, 0).Select
    ActiveSheet.Paste
    Range("A1").Select
    ActiveWorkbook.Worksheets("Results").Select
Re: Code issue
:D Please attach your example file for testing and fixing.
sna
Re: Code issue
Post by sna »
Thanks fixed it
