Private Sub TextBox1_AfterUpdate()
If Me.TextBox1.Value <> "" Then
Dim irow As Long
Dim ws As Worksheet
Set ws = Worksheets("Sheet2")
Me.TextBox1.Text = Application.Trim(Me.TextBox1.Text)
'Find first empty row in database
irow = ws.Cells(Rows.Count, 1) _
.End(xlUp).Offset(1, 0).Row
'Copy The Data To The Database
ws.Cells(irow, 1).Value = Me.TextBox1.Value
ws.Cells(irow, 1).Select
Me.TextBox1 = ""
Me.TextBox1.SetFocus
MsgBox "no product", vbCritical
Option Explicit
Sub RoundedRectangle1_Click()
Dim s As Range
Dim tg As Range
Dim tg3 As Range
Set s = Worksheets("Sheet1").Range("B1")
Set tg = Worksheets("Sheet2").Range("A365").End(xlUp).Offset(1, 0)
Set tg3 = Worksheets("Sheet3").Range("A365").End(xlUp).Offset(1, 0)
s.Copy
tg.PasteSpecial xlPasteValues
tg3.PasteSpecial xlPasteValues
Option Explicit
Dim s As Range
Dim tg As Range
'Dim tg3 As Range
Set s = Worksheets("Sheet1").Range("B1:C7")
Set tg = Worksheets("Sheet2").Cells(1, Cells.Columns.Count).End(xlToLeft).Offset(0, 1)
'Set tg3 = Worksheets("Sheet3").Range("A1").End(xlToLeft).Offset(0, 1)
s.Copy
'tg3.PasteSpecial xlPasteValues
