Option Explicit
Private Sub TempCombo_KeyDown(ByVal _
KeyCode As MSForms.ReturnInteger, _
ByVal Shift As Integer)
'Hide combo box and move to next cell on Enter and Tab
Select Case KeyCode
Case 9
ActiveCell.Offset(0, 1).Activate
Case 13
ActiveCell.Offset(1, 0).Activate
Case Else
'do nothing
End Select
Dim str As String
Dim cboTemp As OLEObject
Dim ws As Worksheet
Set ws = ActiveSheet
On Error GoTo errHandler
If Target.Count > 1 Then GoTo exitHandler
Set cboTemp = ws.OLEObjects("TempCombo")
If cboTemp.Visible = True Then
With cboTemp
.Top = 10
.Left = 10
.ListFillRange = ""
.LinkedCell = ""
.Visible = False
.Value = ""
If Target.Validation.Type = 3 Then
str = Target.Validation.Formula1
str = Right(str, Len(str) - 1)
With cboTemp
.Visible = True
.Left = Target.Left
.Top = Target.Top
.Width = Target.Width + 15
.Height = Target.Height + 5
.ListFillRange = ws.Range(str).Address
.LinkedCell = Target.Address
cboTemp.Activate
exitHandler:
errHandler:
Resume exitHandler
