JV
sna
Excel Ver: Excel 365
JV
Post by sna »
Hi Dear
I need to show the result as in attached file in Menu Sheet Column K To L
Thanks
sna
Re: JV
Post by sna »
Herewith attached
Re: JV
:D Please provide source of data and show its result for easy to understand then attach the updated file again.
sna
Re: JV
Post by sna »
Hi Dear
Sorry for not clear explanation.
The source data is in Sheet Menu.The data from B11:Ixx coming from Source C1:C8 data entries.the main point of this template I want to create accrued expenses tracking by inputing data in Sheet Menu including PL Code and GL Code but the PL and GL in the same line(row) but in the JV it should be line separately.it means Dr PL(exp) and Cr GL(accrued expenses) and it should be like K10:M13.in JV sheet
Debit Credit amount
61095 100
USD17223 (100)
Thanks
Re: JV
:D The example code is below:
Dim n As Long, t As Long
With S1
    t = .Range("h" & .Rows.Count).End(xlUp).Row + 1
    .Range("b" & t).Resize(1, 6).Value = _
        Application.Transpose(.Range("c1:c6").Value)
    .Range("h" & t + 1).Value = .Range("c7").Value
    .Range("c1:c8").ClearContents
    .Range("c1").Select
sna
Re: JV
Post by sna »
Hi Dear
Thank.got it but once more I need to click button JV it will copy data to JV as in attached
I attached new sheet
Best wishes
Re: JV
:D Try with this code:
Dim r As Range
S1.Range("g11:h1000").Copy S2.Range("a11")
S1.Range("d11:d1000").Copy S2.Range("d11")
For Each r In S2.Range("d11:d" & S2.Range("d" & S2.Rows.Count).End(xlUp).Row + 1)
    If r.Value = "" Then
        r.Value = -r.Offset(-1, 0).Value
S1.Range("e11:e1000").Copy S2.Range("e11")
For Each r In S2.Range("e11:e" & S2.Range("e" & S2.Rows.Count).End(xlUp).Row + 1)
        r.Value = r.Offset(-1, 0).Value
sna
Re: JV
Post by sna »
Range("C11").FormulaR1C1="IFERROR(VLOOKUP (IF(RC[-1]="""",RC[-2],RC[-1]),table1,2,0),"""")"
Range("C11:C1000").AutoFill Destination:=Range("C11:C1000")
Thank you so much . another way I use above code to add to your code but
In your code provided,I need to look up account name from PL or GL in Sheet Journal but don't require formula just values
Best Regards,
sna
Re: JV
Post by sna »
Hi dear
I update a file by creating a code to copy data from S1 To S4 but it has blank rows and another one is Vlookup account name in S2.
Could you please kindly take a look?
Best Regards
Re: JV
sna wrote: Tue Nov 17, 2020 9:26 am I need to look up account name from PL or GL in Sheet Journal but don't require formula just values
:D Copy your code and paste as values with this line after auto fill.
Range("C11:C19").value = Range("C11:C19").value
sna
Re: JV
Post by sna »
I mean I want to copy from Sheet menu to sheet Listing base on header.in JV I need to look up account name from COA but my code not work well in Module 2 and 3
Re: JV
:D Please attach file with the latest code (include my code above) and explain what the correct result that you want.
sna
Re: JV
Post by sna »
I need to copy from data in sheet Menu to Sheet Listing without blank rows base on column headers.fill account name in Sheet Journal as in Sample attached file
Thanks
sna
Re: JV
Post by sna »
Here is an attachment
sna
Re: JV
Post by sna »
I upload sample with expected Result and code update in Book1(3).xlsm
In Sheet Listing I need to copy data from Sheet Menu matching column headers in Sheet Listing and paste here.In Sheet JV I need to look up account name from Sheet COA by using Vlookup in vba and convert to values.
Hope everything is fine tune
Thanks
sna
Re: JV
Post by sna »
Hi Dear ,
Now come up with issue.I have withholding tax so how do I amend code to be like in Sheet Menu and Sheet Journal.I mean as soon as I put data entry click button add it will show like Menu and I click journal button it will show as journal sheet.
please kindly help
Thank in advance
sna
Re: JV
Post by sna »
Here is a new update template
Re: JV
:D Please adjust sub procedure named AddNew() by yourself first if it has any problem you can post that code and attach the latest file again.
sna
Re: JV
Post by sna »
Now my template intuitive change.just close it
BTW thanks you so much
