Send mail
sna
Excel Ver: Excel 365
Send mail
Post by sna »
Dim olApp As Outlook.Application
Dim olMail As MailItem
Dim flname As String
Dim wkb As Workbook
flname = VBA.Environ("temp") & "\" & VBA.Format(VBA.Now, "dd_mm_yyy_hh_mm_ss") & ".xlsx"
Set olApp = New Outlook.Application
Set olMail = olApp.CreateItem(olMailItem)
Set wkb = Workbooks.Add ' add new workbook
' change sheet name and range here
ThisWorkbook.Sheets(1).Range("A1:g25").Copy Destination:=wkb.Sheets(1).Range("a1")
wkb.SaveAs flname ' save workbook with temp name
wkb.Close 'close it
With olMail
    .To = "abc@gmail.com"
    .Subject = "Hello"
    '  vbNewLine  is used to insert a row
    .Body = "Dear " & vbNewLine & "Please find the attachment" & vbNewLine & vbNewLine & vbNewLine & "Regards" & vbNewLine & "email"
    .Attachments.Add flname  ' attach the workbook
    .Display ' or use .send
Set wkb = Nothing
Set olMail = Nothing
Set olApp = Nothing
I need to tweak to loop mail Id and sent to them
Best Regards,
Re: Send mail
:D Please attach the macro file that have your code inside.
Macro file extension is '.xlsm' or '.xlsb' not '.xlsx' in post #1.
sna
Re: Send mail
Post by sna »
See attached
Re: Send mail
sna wrote: Mon Sep 28, 2020 7:51 am I need to tweak to loop mail Id and sent to them
:D The example code for looping as below:
Dim r As Range
With thisworksheet
    For Each r In .Range("o3", .Range("o" & .Rows.Count).End(xlUp))
        With olMail
            '.To = "abc@gmail.com"
            .To = r.Value
            .Subject = "Hello"
sna
Re: Send mail
Post by sna »
How can we send only PDF?
Re: Send mail
:D You can send PDF file with this code, just make this statement flname = VBA.Environ("temp") & "\" & VBA.Format(VBA.Now, "dd_mm_yyy_hh_mm_ss") & ".xlsx" refer to PDF file instead.
sna
Re: Send mail
Post by sna »
Thank you
