VBA copy date
sna
Excel Ver: Excel 365
VBA copy date
Post by sna »
Hi Dear
I try to write code to loop through files in a folder path.
The file name located in cell of column AD.i want to find if cell value in column AD match file name in the folder path it would loop through sheet to find date from column K or L if column N=0 and column O >0 then offset one row until column N>0 and column O>0 then return date from that row and place date on column AG.if file not found place file not found on AG.and if the data is blank place no data on AG too
Best wishes,
I also attached working file
Restructure loan EMI.xlsm
(39.71 KiB) Downloaded 16 times
sna
Re: VBA copy date
Post by sna »
One more thing if data on col AG same as date col in U place OK on col AJ
Re: VBA copy date
sna wrote: Mon Aug 24, 2020 9:28 pm I try to write code to loop through files in a folder path.
:D Could you please attach some file on column AD for test your code?
sna
Re: VBA copy date
Post by sna »
Hi Dear
Here is an attached file
Best wishes
PSN_EMI - LD1916105734 - TAING BUNNGUN.xlsx
(15.57 KiB) Downloaded 13 times
Re: VBA copy date
:D Try with this code.
Sub Import_StartDate()
    Dim wk As Workbook, path As String, Fname As String
    Dim Rng As Range, Dn As Range, Cel As Range
    Dim Ng As Range, Fdt As Range
    Dim Dt As Range, SRn As String
    Dim Vdt As String, FileName As String
    Dim ThisWb As String, Ndata As Double
    Dim i As Long, j As Long
    ThisWb = ThisWorkbook.Name
    path = "\\op023\Data Center\OPERATION DEPARTMENT\4- CENTRALIZED OPERATION UNIT\4- Restructure Loan in 2020\Schedule Before and After\"
    Set Rng = RST1.Range(Range("AD3"), Range("AD" & Rows.Count).End(xlUp))
    For Each Dn In Rng
        Fname = Dn & ".xlsx"
        FileName = VBA.FileSystem.Dir(path & Fname)
        If FileName = VBA.Constants.vbNullString Then
            Dn.Offset(0, 3) = "File not found"
            Set wk = Workbooks.Open(path & Fname)
            Ndata = Range("K" & Rows.Count).End(xlUp).Row
            If Ndata < 3 Then
                Dn.Offset(0, 3) = "No DATA"
                wk.Close SaveChanges:=False
                Set Cel = Range(Range("K1"), Range("K" & Ndata))
                j = 0
                For i = Cel.Rows.Count To 1 Step -1
                    If Cel(i).Offset(0, 3).Value = 0 And Cel(i).Offset(0, 4) > 0 Then
                        Dn.Offset(0, 3).Value = Cel(i).Offset(1, 0).Value
                        j = j + 1
                        wk.Close False
                        Exit For
        If j = 0 Then
        ThisWorkbook.Activate
    Next Dn
    Call MsgBox("Transtion Completed !!!", vbInformation)
sna
Re: VBA copy date
Post by sna »
Thank you so much
sna
Re: VBA copy date
Post by sna »
One more thing
Sub Checking ()
Dim ThisCell1 As Range
Dim ThisCell2 As Range
    For Each ThisCell1 In Range("AG3:AG9999")
    'This is the range of cells to check
        For Each ThisCell2 In Range("U3:U9999")
        'This is the range of cells to compare
            If ThisCell1.Value = ThisCell2.Value Then
                ThisCell1.Offset(, 3).Value = "TRUE"
                Exit For
            Next ThisCell2
        Next ThisCell1
This process is slow what's wrong?
Best regards
Re: VBA copy date
:D This code loop many cells (9997 * 9997).
sna
Re: VBA copy date
Post by sna »
How to fix this?
Thanks
Re: VBA copy date
:D Your code should scope only data not fixed range.
sna
Re: VBA copy date
Post by sna »
Ok thanks
