สอบถามเรื่อง เพราะเหตุใด Event ของ Button ทำงานไม่เหมือนกัน
cheapache
Post by cheapache »
    Public Sub btnTransfer_Click(sender As Object, e As EventArgs) Handles btnTransfer.Click
        If txtMaximumTank.Text <= txtVolumeWater.Text Then
            Dim result14 As DialogResult = MessageBox.Show("The capacity of the tank is less than that required to maintain the water level.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
            If txtMaximumTank.Text = "" Then
                Dim result As DialogResult = MessageBox.Show("Please you specify maximum capacity of tank.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtVolumeWater.Text >= txtMaximumTank.Text Then
            Dim result15 As DialogResult = MessageBox.Show("The water level you specify exceeds tank capacity.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
            If txtVolumeWater.Text = "" Then
                Dim result1 As DialogResult = MessageBox.Show("Please you specify level water do you need maintain.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
                ' result1.OK Then
                'txtVolumeWater.Text = (txtMaximumTank.Text - 2)
                'End If
        If txtCapacityA.Text = "" Then
            Dim result2 As DialogResult = MessageBox.Show("Please you speccify capacity of bottle fertilizer A.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtCapacityB.Text = "" Then
            Dim result3 As DialogResult = MessageBox.Show("Please you speccify capacity of bottle fertilizer B.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtFertilizerA.Text = "" Then
            Dim result4 As DialogResult = MessageBox.Show("Fertilizer A 2 CC. per liquid 1 liter.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtFertilizerB.Text = "" Then
            Dim result5 As DialogResult = MessageBox.Show("Fertilizer B 2 CC. per liquid 1 liter.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtTemp.Text = "" Then
            Dim result6 As DialogResult = MessageBox.Show("Please you specify temperature value of water (should not more than 35 °C.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtHumidity.Text = "" Then
            Dim result7 As DialogResult = MessageBox.Show("Please you specify Humidity value for control. (Should between value 40-60 %Rh.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtEc.Text = "" Then
            Dim result8 As DialogResult = MessageBox.Show("Please you specify EC value.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtEC2.Text = "" Then
            Dim result16 As DialogResult = MessageBox.Show("Please you specify EC value.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtEC3.Text = "" Then
            Dim result17 As DialogResult = MessageBox.Show("Please you specify EC value.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtEC4.Text = "" Then
            Dim result18 As DialogResult = MessageBox.Show("Please you specify EC value.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If CheckBox1.Checked = True Then
            If txtpHMin.Text Or txtpHMax.Text = "" Then
                Dim result9 As DialogResult = MessageBox.Show("Please you specify pH value (The value should between 5.5 - 6.2)", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Question)
                'Exit Sub
        ElseIf CheckBox1.Checked = False Then
            Dim result13 As DialogResult = MessageBox.Show("pH function closed.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Question)
        If TextBox5.Text = "" Then
            Dim result10 As DialogResult = MessageBox.Show("Please you specify time of grow.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If TextBox3.Text = "" Then
            Dim result11 As DialogResult = MessageBox.Show("Please you specify time for delay before put fertilizer B.", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        If txtFlowwater.Text = "" Then
            Dim result12 As DialogResult = MessageBox.Show("Please you specify time for flow normal water", "System message : ", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        Dim variableTank As Integer = txtMaximumTank.Text
        Dim variableVolumeTank As Integer = txtVolumeWater.Text
        Dim capacityA As Integer = txtCapacityA.Text
        Dim capacityB As Integer = txtCapacityB.Text
        Dim variableTemp As Integer = txtTemp.Text
        Dim variableHumi As Integer = txtHumidity.Text
        Dim variableEC As Double = txtEc.Text
        Dim variableEC2 As Double = txtEC2.Text
        Dim variableEC3 As Double = txtEC3.Text
        Dim variableEC4 As Double = txtEC4.Text
        Dim variableA As Integer = txtFertilizerA.Text
        Dim variableB As Integer = txtFertilizerB.Text
        Dim variablepHMin As Double = (CDbl(txtpHMin.Text))
        Dim variablepHMax As Double = (CDbl(txtpHMax.Text))
        Dim variablephMin2 As Double = 1.0
        Dim variablephMax2 As Double = 1.0
        Dim variableDay As Integer = TextBox5.Text
        Dim variableMin As Integer = TextBox3.Text
        Dim variableFlow As Integer = txtFlowwater.Text
        PumpFlow = 2
        ValveFeedin = 2
        ValveFeedout = 2
        PumpA = 2
        PumpB = 2
        ValveFogger = 2
            data = ("" & variableTank & "" & variableVolumeTank & "" & capacityA & "" & capacityB & "" & variableA & "" & variableB & "" & variableTemp & "" & variableHumi & "" & (variableEC * 10) & "" & (variableEC2 * 10) & "" & (variableEC3 * 10) & "" & (variableEC4 * 10) & "" & (variablepHMin * 10) & "" & (variablepHMax * 10) & "" & variableDay & "" & variableMin & "" & variableFlow & "" & PumpFlow & "" & ValveFeedin & "" & ValveFeedout & "" & PumpA & "" & PumpB & "" & ValveFogger & "\")
            data = ("" & variableTank & "" & variableVolumeTank & "" & capacityA & "" & capacityB & "" & variableA & "" & variableB & "" & variableTemp & "" & variableHumi & "" & (variableEC * 10) & "" & (variableEC2 * 10) & "" & (variableEC3 * 10) & "" & (variableEC4 * 10) & "" & (variablephMin2 * 10) & "" & (variablephMax2 * 10) & "" & variableDay & "" & variableMin & "" & variableFlow & "" & PumpFlow & "" & ValveFeedin & "" & ValveFeedout & "" & PumpA & "" & PumpB & "" & ValveFogger & "\")
        ListBox1.Items.Add(data)
        'SerialPort1.PortName = comport
        'SerialPort1.BaudRate = baudrate
        'SerialPort1.Open()
        'If SerialPort1.IsOpen Then
        'SerialPort1.WriteLine(data)
        'SerialPort1.Close()
        'End If
ด้านบนนี้เป็นโค๊ดที่ใช้งานได้ปกติครับ แต่ถ้าหากไม่กดปุ่มนี้ก่อน แล้วไปกดปุ่มอื่นที่มีคำสั่งเหมือนกัน โปรแกรมจะแจ้งว่า ให้ Convert from string to integer
 Dim variableTank As Integer = (CInt(txtMaximumTank.Text))
        PumpFlow = 0
        'data = ("" & variableTank & "" & variableVolumeTank & "" & variableTemp & "" & variableHumi & "" & (variableEC * 10) & "" & variableA & "" & variableB & "" & variableDay & "" & variableMin & "" & (variablepHMin * 10) & "" & (variablepHMax * 10) & "\")
        'data1 = ("" & txtMaximumTank.Text & "\")
        'SerialPort1.Open()
        'End If
ผมลองใส่ CInt ตรงที่โปรแกรมแจ้ง error แล้วครับ แต่ก็ยังไม่หาย ไม่ทราบว่าเกิดจากอะไรครับ รบกวนอาจารย์ด้วยครับ
Re: สอบถามเรื่อง เพราะเหตุใด Event ของ Button ทำงานไม่เหมือนกัน
:D ลอง Run ทีละ Step แล้วสังเกตว่าติดตรงบรรทัดใดครับ
cheapache
Post by cheapache »
ลองรันทีละ step ดูแล้วครับ พอชี้ที่ ตัวแปร txtMaximumtank.text มันขึ้นว่ายังเป็น "" อยู่หมายถึงไม่มีค่าตัวแปร
แต่เมื่อลองเอา msgbox(txtMaximumtank.text) เช็คตอนฟอร์มโหลด มันขึ้น 12 ครับ แต่ทำไมตอนกดปุ่ม ค่าใน txtMaximumtank.txt ในตอนแรกถึงยังเป็น "" เพราะเมื่อเปิดฟอร์มใหม่ขึ้นมา ผมเขียนให้ข้อมูลที่อยู่ใน textbox.text ทุกตัว ถูกเก็บไว้ใน My.Setting()
:D เช็คตอน Form Load แล้วได้ค่านั้นแสดงว่ามันต้องมีค่าอยู่ใน ตัวแปร txtMaximumtank อยู่ก่อนที่จะคลิกปุ่มอื่น
หากเป็นเช่นนี้ Code ไม่ควร Error ยกเว้นปิด Form นั้นไปแล้วค่าจึงจะถูกลบออกจาก Memory ครับ
