problem of sum
sna
Excel Ver: Excel 365
problem of sum
Post by sna »
Hi Dear
I have a problem with sum up values
Attached a template with expect result
Best Wishes,
Re: problem of sum
:D What are the expected cells and how to get it?
sna
Re: problem of sum
Post by sna »
Hi Dear,
the expected results in column L.
I test formula in M3 but it returned 0
Best Wishes
norkaz
Excel Ver: 2013,365
Re: problem of sum
Post by norkaz »
Hi Guy,
Refer to the expected results in column L.
I would like to know how the sample results as attached for L3 =110 ,L6=120, L24=110 become? I mean what is the criteria to get them all?
Norkaz
sna
Re: problem of sum
Post by sna »
The criteria in column P & R
norkaz
Excel Ver: 2013,365
Re: problem of sum
Post by norkaz »
Hi Guy,
I'm still uncelar about your points.
I know the criteria is in column P&R actually by refer to your testing formula in M3.
However, the sample answers that you placed in L3 = 110 , L6 =120, L21=110 look like impossible to return like that numbers by refer to the SUMIFS formula method in M3 because of the criteria R:R,"<="&F3.
No values in column "R" less than or equal "F3" position, then the results that the testing formula return 0 should be the exact answer.
Then if you need the results return by the sample answers in L3=110 , L6=120, L21=110 , I would like to know about the calculation method to get them all by manual calculation.
Norkaz
