Drop down without blank Cells
sna
Excel Ver: Excel 365
Post by sna »
Hi Dear
Hope everyone here safe
I need your help to do data validation from cells ignoring blanks.
I can use a helper and named range to do.
Is it having a formula or UDF to do this without helper just use only named range?
Thanks
sna
Re: Drop down without blank Cells
Post by sna »
Here is an attached
:D The validation can't accept array either by direct formula or formula in name manager. If you need VBA please try by yourself first.
sna
Post by sna »
Noted.Thank you so much
