sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Fri Oct 01, 2021 4:38 pm
Hi Dear,
I need your help how to return value from two columns to the another columns with swapping columns.
I need results in color cells
Thanks
Posts: 31265 Joined: Sun Jan 24, 2010 12:33 pm
by snasui » Fri Oct 01, 2021 5:03 pm
You can use these formulas,
C2
=IF(ISODD(COLUMNS($C2:C2)),INDEX($A$2:$A$5,INT((COLUMNS($C2:C2)-1)/2)+1),"")
Enter > Copy to the right
C3
=IF(ISODD(COLUMNS($C2:C2)),INDEX($B$2:$B$5,INT((COLUMNS($C2:C2)-1)/2)+1),"")
sna
by sna » Fri Oct 01, 2021 7:26 pm
it is working thank you so much
