Copy word table to excel
sna
Excel Ver: Excel 365
Post by sna »
Hi Dear,
I need to copy from table word doc to excel .
I used this code form google but not working.
fine,I need to copy all table in word to a single sheet in excel.
I upload the file
Thanks
Re: Copy word table to excel
:D The example code is below:
With wdDoc
    For t = 1 To .Tables.Count
        Set xlWkSht = Sheets("Menu")
        .Tables(t).Range.Copy
        With xlWkSht
            If .Range("a1").Value = "" Then
                .Paste .Range("A1")
                .Paste .Range("a" & .Rows.Count).End(xlUp).Offset(1, 0)
            c = .UsedRange.Columns.Count
            r = .UsedRange.Columns.Count
            .Range("A1:" & .Cells(r, c).Address).WrapText = False
    Next t
sna
Post by sna »
I test the code it is working but not completely copied tables
:D Please post the correct result for easy to compare and fix VBA code.
sna
Post by sna »
I test it again it works but not fit column width
With xlWkSht
        .Paste .Range("A1")
        .Paste .Range("a" & Rows.Count).End(xlUp).Offset(1)
    .UsedRange.WrapText = False
    .UsedRange.EntireColumn.AutoFit
    .UsedRange.EntireRow.AutoFit
sna
Post by sna »
Thank you 🙏
