ReconcileTxn
sna
Excel Ver: Excel 365
ReconcileTxn
Post by sna »
Hi Dear
I have an issue I need to copy data from sheet Reconcile Txn to Backup Sheet but not empty.
what should I add or edit my code to do that?
sna
Re: ReconcileTxn
Post by sna »
Please refer to this template .I also need your help how to clear data more dynamic(Module 1 and 2)
Thanks
Re: ReconcileTxn
:D The example code is below:
Sub CL()
    'RCL2.[A6:Y100].ClearContents
    With RCL2
        .Range("a6:y" & .Range("a" & .Rows.Count).End(xlUp).Row).ClearContents
sna
Re: ReconcileTxn
Post by sna »
thank how about copy and paste without blank rows in Module 3?
Re: ReconcileTxn
With RCL1
    r = [Sumproduct(--('RECONCILE TXN'!b12:b100<>""))]
    .Range("b12:z12").Resize(r).Copy
    RCL4.Range("a1").PasteSpecial xlPasteValues
sna
Re: ReconcileTxn
Post by sna »
Thank you 🙏
sna
Re: ReconcileTxn
Post by sna »
    If Intersect(Target, Range("B:B")) Is Nothing Then Exit Sub
    Range("B" & Target.Row).Resize(, 20).Copy Sheets("Sheet2").Cells(Rows.Count, "A").End(xlUp).Offset(1, 0)
your code work fine,is it possible like this??
or we can use special cell constant?
Thank you once again
Re: ReconcileTxn
:D It possible to do everything with code. Try with yourself for your task, post the error and attach file to here.
sna
Re: ReconcileTxn
Post by sna »
Thank you 🙏
sna
Re: ReconcileTxn
Post by sna »
I test
Range("B" & Target.Row).Resize(1, 20).Copy RCL4.Cells(Rows.Count, "A").End(xlUp).Offset(1, 0)
it is not working !
Re: ReconcileTxn
:D You need to post code with code style such as post #7.
Attach the updated file that have your latest code inside and explain what you want to do and point to the expected result from your code.
sna
Re: ReconcileTxn
Post by sna »
    Range("B" & Target.Row).Resize(, 20).Copy RCL4.Cells(Rows.Count, "A").End(xlUp).Offset(1, 0)
I need to copy from RCL1 to RCL4 without empty cells
Best wishes
Re: ReconcileTxn
snasui wrote: Sat Oct 10, 2020 6:58 am Attach the updated file that have your latest code inside and explain what you want to do and point to the expected result from your code.
Please read my post above carefully.
sna
Re: ReconcileTxn
Post by sna »
Here's the attached file for your reference
Thanks
Re: ReconcileTxn
:D You can call 'CopyNonBlankValue' as below.
'    Range("B" & Target.Row).Resize(, 24).Copy RCL4.Cells(Rows.Count).End(xlUp).Offset(1)
    Call Module3.CopyNonBlankValue
sna
Re: ReconcileTxn
Post by sna »
Ok.thank will update you
