Sub Save»éÒ¢ÒÂʴ˹éÒÃéÒ¹()
' Save»éÒ¢ÒÂʴ˹éÒÃéÒ¹ Macro
With SheetDatabase
If .Range("D13") = "" Then
MsgBox "Your data not complete. Please verify and try again."
A = MsgBox("µéͧ¡Òúѹ·Ö¡", vbCritical + vbYesNo)
If A = vbYes Then
For i = 1 To 1
Application.Goto Reference:="msrec»éÒ¢ÒÂʴ˹éÒÃéÒ¹"
Selection.Copy
Application.Goto Reference:="uldt»éÒ¢ÒÂʴ˹éÒÃéÒ¹"
Selection.End(xlDown).Select
ActiveCell.Offset(1, 0).Range("A1").Select
:=False, Transpose:=False
Sheets("Home").Select
Range("B5").Select
Selection.ClearContents
Sub SaveBlue()
' SaveBlue Macro
With Sheets("Database")
If .Range("D13").Value = "" Then
A = MsgBox("Are you sure?", vbCritical + vbYesNo)
If A = vbYes Then
Application.Goto Reference:="msrecBlue"
Selection.Copy
Application.Goto Reference:="uldtBlue"
ActiveSheet.Range("a" & Rows.Count).End(xlUp).Offset(1, 0).Select
Range("B5").Select
ไม่ทราบว่ามีการทำงานในลักษณะวนซ้ำๆ หรือเปล่าครับ หากไม่มี ผมขอเอา For ... Next ออกนะครับ
Sub ChooseBlueReccord()
' Macro1 Macro
Dim r As Range, rBlue As Range
With ActiveSheet
Set rBlue = .Range("dtblue")
For Each r In rBlue
If Len(r.Value) < 1 Then r.Clear
Set rBlue = .Range("dtblue").SpecialCells(xlCellTypeConstants)
rBlue.Select
