Sub Macro1()
' Macro1 Macro
Dim j, result, lastrow, a As Long
j = Worksheets("Sheet2").Range("G3").Value
lastrow = Worksheets("Sheet1").UsedRange.Rows.Count
For Row = 3 To lastrow
If j = True Then
Sheets("Sheet2").Select
result = Sheets("Sheet2").Range("B" & Row).Copy
Sheets("Sheet3").Select
a = Sheets("Sheet3").Range("B" & Row).PasteSpecial
Row = Row + 1
Next
Sub test()
Dim rAll As Range, r As Range
With Sheets("Sheet2")
Set rAll = .Range("g3", .Range("g" & .Rows.Count).End(xlUp))
Sheets("Sheet3").Range("b3:e1000").ClearContents
For Each r In rAll
If r.Value = True Then
With Sheets("Sheet3")
If .Range("b3").Value = "" Then
.Range("b3").Value = r.Offset(0, -5).Value
.Range("b" & .Rows.Count).End(xlUp).Offset(1, 0).Value = r.Offset(0, -5).Value
Dim ws1 As Worksheet
Dim ws2 As Worksheet
Dim ws3 As Worksheet
Dim rRange As Range
Dim nRange As Range
Dim lRange As Range
Dim nlRange As Range
Dim tRange As Range
Dim ntRange As Range
Dim lngws1LastRow As Long
Dim lngws2LastRow As Long
Dim lngws3LastRow As Long
Set ws1 = Sheets("Sheet1")
Set ws2 = Sheets("Sheet2")
Set ws3 = Sheets("Sheet3")
lngws1LastRow = ws1.Range("G" & ws1.Rows.Count).End(xlUp).Row
lngws2LastRow = ws2.Range("B" & ws2.Rows.Count).End(xlUp).Row
Set rRange = ws1.Range("G3:G" & lngws1LastRow)
Set lRange = ws2.Range("B3:B" & lngws2LastRow)
Set tRange = ws3.Range("B3:E100")
tRange.ClearContents
For Each nRange In rRange
If nRange Then
For Each nlRange In lRange
If nlRange = nRange.Offset(0, -5) Then
nlRange.Offset(0, 0).Resize(1, 4).Copy
lngws3LastRow = ws3.Range("B" & ws3.Rows.Count).End(xlUp).Row
ws3.Range("B" & lngws3LastRow + 1).PasteSpecial xlPasteValues
Next nlRange
Next nRange
