mpmp3m7lpm
Posts: 18 Joined: Fri Jan 30, 2015 12:41 pm
by mpmp3m7lpm » Fri Feb 06, 2015 7:27 pm
by snasui » Fri Feb 06, 2015 8:04 pm
ตัวอยาง Code ครับ
If item_in_review = Search.TextBox1.Text Or _
(Len(Sheets("Data2").Range("E" & row_number).Value) > 0 And _
Sheets("Data2").Range("E" & row_number).Value = Search.TextBox2.Text) Or _
(Len(Sheets("Data2").Range("H" & row_number).Value) > 0 And _
Sheets("Data2").Range("H" & row_number).Value = Search.TextBox3.Text) Then
Repair.TextBox1.Text = Sheets("Data2").Range("A" & row_number)
Repair.TextBox2.Text = Application.Text(Sheets("Data2").Range("B" & row_number), "dd/mm/yyyy")
Repair.TextBox3.Text = Sheets("Data2").Range("C" & row_number)
Repair.TextBox4.Text = Sheets("Data2").Range("D" & row_number)
Repair.TextBox5.Text = Sheets("Data2").Range("E" & row_number)
Repair.TextBox6.Text = Sheets("Data2").Range("F" & row_number)
Repair.TextBox7.Text = Sheets("Data2").Range("G" & row_number)
Repair.TextBox8.Text = Sheets("Data2").Range("H" & row_number)
Repair.TextBox9.Text = Sheets("Data2").Range("I" & row_number)
Repair.TextBox10.Text = Sheets("Data2").Range("J" & row_number)
Exit Do
