superbill
Posts: 29 Joined: Sun May 05, 2013 11:59 am
by superbill » Thu Jul 31, 2014 5:06 pm
ต้องการคั่นข้อมูลระหว่าง Column ด้วย Pipe (|) ตอนนี้ผมหา Code VBA ได้แล้ว แต่ติดปัญหาตรงที่ Column ผมมีเยอะตั้งแต่ A-AO พอนำ Code ไปวางแล้วมันฟ้องเหมือนกับว่ายาวเกินไป Code ที่ผมใช้คือ
Sub AddPipe()
Dim Handle As Integer, File_Name As String
Dim Row As Long, PutStr As String
Dim sh As Worksheet
Dim wb As Workbook
Set wb = ThisWorkbook
For Each sh In wb.Worksheets
File_Name = "D:\" & sh.Name & ".csv"
Handle = FreeFile
If Dir(File_Name) <> "" Then Kill File_Name
Open File_Name For Binary As Handle
Row = 0
Range("A1").Select
Do Until Selection.Value = ""
Row = Row + 1
PutStr = Range("A" & Row).Value & "|" & _
Range("B" & Row).Value & "|" & _
Range("C" & Row).Value & "|" & _
Range("D" & Row).Value & "|" & _
Range("E" & Row).Value & "|" & _
Range("F" & Row).Value & "|" & _
Range("G" & Row).Value & "|" & _
Range("H" & Row).Value & "|" & _
Range("I" & Row).Value & "|" & _
Range("J" & Row).Value & "|" & _
Range("K" & Row).Value & "|" & _
Range("L" & Row).Value & "|" & _
Range("M" & Row).Value & "|" & _
Range("N" & Row).Value & "|" & _
Range("O" & Row).Value & "|" & _
Range("P" & Row).Value & "|" & _
Range("Q" & Row).Value & "|" & _
Range("R" & Row).Value & "|" & _
Range("S" & Row).Value & "|" & _
Range("T" & Row).Value & "|" & _
Range("U" & Row).Value & "|" & _
Range("V" & Row).Value & "|" & _
Range("W" & Row).Value & "|" & _
Range("X" & Row).Value & "|" & _
Range("Y" & Row).Value & "|" & _
Range("Z" & Row).Value & "|" & _
Range("AA" & Row).Value & "|" & _
Range("AB" & Row).Value & "|" & _
Range("AC" & Row).Value & "|" & _
Range("AD" & Row).Value & "|" & _
Range("AE" & Row).Value & "|" & _
Range("AF" & Row).Value & "|" & _
Range("AG" & Row).Value & "|" & _
Range("AH" & Row).Value & "|" & _
Range("AI" & Row).Value & "|" & _
Range("AJ" & Row).Value & "|" & _
Range("AK" & Row).Value & "|" & _
Range("AL" & Row).Value & "|" & _
Range("AM" & Row).Value & "|" & _
Range("AN" & Row).Value & "|" & _
Range("AO" & Row).Value & vbCrLf
Put Handle, , PutStr
Selection.Offset(1, 0).Select
Close Handle
Next sh
ไม่ทราบว่าพอมีวิธีเขียนให้มันสั้นกว่านี้รึเปล่าครับ
by snasui » Thu Jul 31, 2014 5:36 pm
ลองแนบไฟล์ตัวอย่างพร้อมภาพที่ฟ้องมาด้วยครับ
superbill
by superbill » Thu Jul 31, 2014 5:42 pm
คือถ้าลองก๊อปปี้ Code จากด้านบนไปใส่ใน Macro ของ Excel จะขึ้น error ว่า Too Many Line Continuations ครับ
by snasui » Thu Jul 31, 2014 7:33 pm
ตัวอย่างการปรับ Code ครับ
Sub AddPipe()
Row = 0
PutStr = ""
Range("A1").Select
Row = Row + 1
For Each r In Range("A" & Row, Range("AO" & Row))
PutStr = PutStr & r & "|"
PutStr = VBA.Left(PutStr, Len(PutStr) - 1) & vbCrLf
superbill
by superbill » Thu Jul 31, 2014 10:45 pm
ขอโทษนะครับ ผมไม่ค่อยมีความรู้ด้าน VBA สักเท่าไร ยังงงๆ ดูไม่ออก ว่าควรจะปรับตรงไหน ผมได้แนบไฟล์ตัวอย่างมาให้ครับ รบกวนด้วยนะครับ ด่วนมากๆ เลย
by snasui » Thu Jul 31, 2014 11:19 pm
การใช้ VBA ต้องเป็นไปตามกฎข้อ 5 ด้านบนครับ
หากยังไม่มีความรู้เกียวกับ VBA ยังไม่ควรใช้ เพราะจะปรับเองไม่ได้แม้จะเป็นการปรับเพียงเล็กน้อย จึงต้องศึกษามาก่อนตามลำดับครับ
