ผมสอบถามข้อมูลลูกค้าในแถวถัดไปไม่ได้ครับ
peeraphat
Post by peeraphat »
สวัสดีครับอาจารย์ผมมีปัญหาสอบถามอาจารย์เรื่องการสอบถามข้อมูลลูกค้าในชีทงาน..
คีย์เงื่อนไขแล้วข้อมูลไม่แสดงข้อมูลครับ..
Option Explicit
Dim customer_data As String
Dim data_row As Single
Dim i As Single
Const db_sheet = "db_customers"
Const id_col = 1
Const sub_col = 2
Const dept_col = 3
Const name_col = 4
Const type_col = 5
Const account1_col = 6
Const account2_col = 7
Const account3_col = 8
Const account4_col = 9
Const account5_col = 10
Const account6_col = 11
With Worksheets(db_sheet)
data_row = 2
'set matching data
If TextBox1.Text = Worksheets(db_sheet).Cells(data_row, id_col).Value And TextBox2.Text = Worksheets(db_sheet).Cells(data_row, sub_col).Value And TextBox3.Text = Worksheets(db_sheet).Cells(data_row, dept_col).Value Then
data_row = data_row + 2
customer_data = "True"
'if id ,sub and dept match, data show
If customer_data = "True" Then
With UserForm1
.TextBox4.Value = Worksheets(db_sheet).Cells(data_row, name_col).Value
.TextBox5.Value = Worksheets(db_sheet).Cells(data_row, type_col).Value
.TextBox6.Value = Worksheets(db_sheet).Cells(data_row, account1_col).Value
.TextBox7.Value = Worksheets(db_sheet).Cells(data_row, account2_col).Value
.TextBox8.Value = Worksheets(db_sheet).Cells(data_row, account3_col).Value
.TextBox9.Value = Worksheets(db_sheet).Cells(data_row, account4_col).Value
.TextBox10.Value = Worksheets(db_sheet).Cells(data_row, account5_col).Value
.TextBox11.Value = Worksheets(db_sheet).Cells(data_row, account6_col).Value
.TextBox12.Value = Worksheets(db_sheet).Cells(data_row, id_col).Value
.TextBox13.Value = Worksheets(db_sheet).Cells(data_row, name_col).Value
'¶éÒ¢éÍÁÙÅäÁèµÃ§¡Ñºà§×è͹ä¢á¨é§àµ×͹
MsgBox ("äÁ辺¢éÍÁÙŹÕé...¡ÃسҵÃǨÊͺÍÕ¡¤ÃÑé§")
'clear both TextBox
TextBox1.Text = vbNullString
TextBox2.Text = vbNullString
TextBox3.Text = vbNullString
TextBox4.Text = vbNullString
TextBox5.Text = vbNullString
TextBox6.Text = vbNullString
TextBox7.Text = vbNullString
TextBox8.Text = vbNullString
TextBox9.Text = vbNullString
TextBox10.Text = vbNullString
TextBox11.Text = vbNullString
TextBox12.Text = vbNullString
TextBox13.Text = vbNullString
'set focus to TextBox1
TextBox1.SetFocus
ขอบคุณอาจารย์ล่วงหน้านะครับ
Re: ผมสอบถามข้อมูลลูกค้าในแถวถัดไปไม่ได้ครับ
:D ลองปรับ Code เป็นด้านล่างครับ
'other code
'set matching data
Do While .Cells(data_row, id_col) <> ""
        Exit Do
    data_row = data_row + 1
'other code
peeraphat
Post by peeraphat »
:thup: :cp: ขอบคุณอาจารย์มากๆครับผม..ทำได้แล้วครับ..
