vba_rearrange_data
sna
Excel Ver: Excel 365
vba_rearrange_data
Post by sna »
Hi Dear!
I need your hand to correct data arranging in a new sheet.I try but it's no luck
Sub FormatLoanData()
    Dim ws As Worksheet
    Dim outputWs As Worksheet
    Dim lastRow As Long
    Dim currentRow As Long
    Dim outputRow As Long
    Dim currentOfficer As String
    ' Set the worksheets
    Set ws = ThisWorkbook.Sheets("RawData") ' Change to your actual data sheet name
    Set outputWs = ThisWorkbook.Sheets.Add
    outputWs.Name = "Output"
    outputRow = 2 ' Start output from the second row
    lastRow = ws.Cells(ws.Rows.Count, 1).End(xlUp).Row ' Get last row with data
    For currentRow = 2 To lastRow ' Assuming first row is header
        ' Check for Credit Officer header
        If InStr(ws.Cells(currentRow, 1), "Credit Officer:") > 0 Then
            currentOfficer = ws.Cells(currentRow, 1).Value ' Store current officer
            ' Skipping the credit officer line
        ElseIf ws.Cells(currentRow, 1).Value <> "" Then
            ' Copy Data to formatted worksheet
            outputWs.Cells(outputRow, 1).Value = ws.Cells(currentRow, 1).Value
            outputWs.Cells(outputRow, 2).Value = ws.Cells(currentRow, 2).Value
            outputWs.Cells(outputRow, 3).Value = ws.Cells(currentRow, 3).Value
            outputWs.Cells(outputRow, 4).Value = ws.Cells(currentRow, 4).Value
            outputRow = outputRow + 1 ' Increment output row counter
    Next currentRow
Please help fix it to get outputs like the hightlighted sheet.
Noted:you can change variable to whatever it is easier to read as well.
thank you in advance
test.xlsb
(26.22 KiB) Downloaded 104 times
Re: vba_rearrange_data
:D The example VBA code for transforming data is below,
Sub TransformData()
    Dim i As Integer, srAll As Range, tgAll As Range, r As Range
    With Worksheets("RawData")
        Set srAll = .Range("a6", .Range("d" & .Rows.Count).End(xlUp))
    With Worksheets("required")
        .UsedRange.ClearContents
        .Range("a1").Resize(srAll.Rows.Count, srAll.Columns.Count) _
            .Value = srAll.Value
        Set tgAll = .Range("b2", .Range("b" & .Rows.Count).End(xlUp))
        For Each r In tgAll
            If IsNumeric(VBA.Right(r.Value, 9)) Then
                r.Offset(0, -1).Value = r.Offset(-1, -1).Value + 1
        tgAll.SpecialCells(xlCellTypeBlanks).EntireRow.Delete shift:=xlUp
sna
Post by sna »
Thanks,I will take a look
sna
Post by sna »
It works perfectly,Thanks so much
