vba
sna
Excel Ver: Excel 365
vba
Post by sna »
Dear All,
I need a simplified vba code to copy some values from Sheet"Date" to Sheet "Paster"
if Cell B1 is 1 so i need to copy data from Sheet "Date" of below data under of 1 in sheet "Date" to Sheet"Paster"
I attach a template
I have no luck
Noted: Dynamic array formula is allowed
Thx
DailyReportOperations-OK.xlsm
(55.07 KiB) Downloaded 132 times
Re: vba
:D The example of code is below.
'Othe code
    ' Loop through each row in the Date sheet and copy rows based on the value in column A
    For i = 2 To lastRowDate
'        If wsDate.Cells(i, 1).Value = cellValue Then
            wsDate.Rows(i).Copy Destination:=wsPaster.Rows(destRow)
            destRow = destRow + 1
'        End If
sna
Re: vba
Post by sna »
I mean to copy only when cell value is 1 equals to column a in sheet "Date" 1 SoSambath 13-09-2024
A Input Office OutSide Authorize Amount
- Transaction 30 - 74 -
- BookingLoan/Reschedule 1 - 1 -
- BookingMCMM/ReEV 1 - - -
- CheckCIF(Credit/FSR) 9 - - -
- PDArrear 7 - 4 -
- RunPayroll 7 - - -
- TaxCar/Payment 1 - - -
- AM(Form50-147) - - 1 -
- ChangeInfomationCIF/ACC - - 1 -
- VMS - - 13 -
B CrossService - - - -
- ReferralPrudential - - - -
- ReferralLoan - - - -
- OtherService - - - -
C Total: 56 - 94 -
D Subtotal: 150 - - -
Re: vba
:D Please try this code.
Sub Test0()
    Dim fOne As Range, fStt As Range
    Dim lstC As Range, srRngs As Range
    If Not IsNumeric(Worksheets("Paster").Range("B1")) Then
        MsgBox "The value in A1 is not a valid number.", vbExclamation
    With Worksheets("Date")
        Set lstC = .Range("b" & .Rows.Count).End(xlUp)
        Set fOne = .Range("a:a").Find(what:=1, LookIn:=xlValues, lookat:=xlPart)
        Set fStt = .Range(fOne, lstC).Find(what:="Subtotal:", LookIn:=xlValues, lookat:=xlPart)
        Set srRngs = .Range(fOne, fStt).Resize(, 6)
    With Worksheets("Paster")
        .Range("b1").CurrentRegion.Offset(1, 0).ClearContents
        .Range("b2").Resize(srRngs.Rows.Count, srRngs.Columns.Count).Value = srRngs.Value
sna
Re: vba
Post by sna »
Thanks so much 🙏
sna
Re: vba
Post by sna »
Hi Dear,
I need to copy all data meet criteria in cell B1 in Sheet Paster .
I attach a template
thx
Test_Daily1.xlsm
(41.17 KiB) Downloaded 124 times
Re: vba
:D The example code is below.
Sub Test1()
    Dim ws As Worksheet
    Dim firstAddress As String
    Dim cell As Range, sv As String
    Dim cpRngs As Range
    Set ws = ThisWorkbook.Sheets("Date")
    Set wt = ThisWorkbook.Sheets("Paster")
    With wt
        sv = wt.Range("b1").Value
        .UsedRange.Offset(1, 0).ClearContents
    Set cell = ws.Columns("B").Find(What:=sv, LookIn:=xlValues, LookAt:=xlWhole)
    If Not cell Is Nothing Then
        firstAddress = cell.Address
        Do
            With ws
                Set cpRngs = .Range(cell, cell.End(xlDown))
            With wt
                cpRngs.Resize(, 6).Copy .Range("b" & .Rows.Count).End(xlUp).Offset(1, 0)
            Set cell = ws.Columns("B").FindNext(cell)
        Loop While Not cell Is Nothing And cell.Address <> firstAddress
sna
Re: vba
Post by sna »
Thanks ,really helpful
