sna
Posts: 699 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Sat Aug 10, 2024 4:15 pm
Hi there,
I need your input how to lookup a value return multiple outputs.
For example I input 203813 it will populate two accounts...
I attach a template
Note excel 2019
norkaz
Posts: 1751 Joined: Wed Jan 12, 2011 7:59 pm
Excel Ver: 2013,365
by norkaz » Sat Aug 10, 2024 9:29 pm
L9
=IFERROR(INDEX(B:B,AGGREGATE(15,6,ROW($C$9:$C$11816)/($K$9=$C$9:$C$11816),ROWS(L$9:L9))),"")
Copy down a column.
M9
=IFERROR(INDEX(F:F,AGGREGATE(15,6,ROW($C$9:$C$11816)/($K$9=$C$9:$C$11816),ROWS(M$9:M9))),"")
Copy down a column.
Bigcat9Excel
Bangkok Thailand
sna
by sna » Sun Aug 11, 2024 6:48 am
Thanks .always helpful
