sna
Posts: 699 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Thu Jul 25, 2024 8:51 am
Hi there!
hope you're all fine
I need your help how use sumifs to work with merge cells without unmerge them
I attach a template
thanks
Posts: 31038 Joined: Sun Jan 24, 2010 12:33 pm
by snasui » Thu Jul 25, 2024 9:20 am
The example formula in F2 is,
=LET(x,SCAN(A2,A2:A7,LAMBDA(a,b,IF(b="",a,b))),MAP(E2:E3,LAMBDA(y,SUM(FILTER(C2:C7,x=y)))))
sna
by sna » Thu Jul 25, 2024 10:04 am
wow,amazing !thanks so much
