sna
Posts: 699 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Mon Jul 15, 2024 3:05 pm
Hi there!
I need to split and pivot the order table.
for example Fred has only 2 orders on 14th and 15th
required excel formula to solve this
Note: excel 365
norkaz
Posts: 1739 Joined: Wed Jan 12, 2011 7:59 pm
Excel Ver: 2013,365
by norkaz » Mon Jul 15, 2024 4:12 pm
Hi
Could you please provide a few sample answers to the fields you’d like to solve in the Excel file? That way, I can assist you more effectively.
Bigcat9
Bangkok Thailand
by puriwutpokin » Mon Jul 15, 2024 6:51 pm
F3=IFERROR(--INDEX(TEXTSPLIT($D3,";"),XMATCH(F$2,TEXTSPLIT($C3,";"))),"") Copy right and down
sna
by sna » Fri Jul 19, 2024 7:54 pm
@puriwutpokin
It works well
sna
by sna » Fri Jul 19, 2024 7:57 pm
How to make it spill range without dragging?
sna
by sna » Wed Jul 24, 2024 9:03 am
puriwutpokin wrote: Mon Jul 15, 2024 6:51 pm
This work,any amendment to make spill range.thanks
by puriwutpokin » Wed Jul 24, 2024 1:37 pm
F3=IFERROR(--INDEX(TEXTSPLIT($D3,";"),XMATCH(F$2:K$2,TEXTSPLIT($C3,";"))),"") Copy down
sna
by sna » Wed Jul 24, 2024 1:37 pm
thanks
