vba not working
sna
Excel Ver: Excel 365
vba not working
Post by sna »
Hi there
i need your help how to check why my code not working for edit and search vba
Please kindly find the attached
thanks
Book_1.xlsb
(23.92 KiB) Downloaded 98 times
Re: vba not working
:D Please provide all steps for testing, what value in each cell and what button has error and what the result if don't any error. You should post the picture of error for easy for verifying.
sna
Re: vba not working
Post by sna »
Hi
It does not show up error.I search by ID if I type 1 it shows the data when click button search and amend data click edit it edit in sheet database but when I type 2 in ID (C5) it doesn't show anything when click search or edit.
Thanks
Re: vba not working
:D You can adjust that code as below.
For n = 2 To x + 1
    If Sheet2.Range("a" & n) = Sheet1.Range("c5") Then
         Sheet1.Range("c7") = Sheet2.Range("b" & n)
         Sheet1.Range("c9") = Sheet2.Range("c" & n)
         Sheet1.Range("c11") = Sheet2.Range("d" & n)
         Sheet1.Range("f5") = Sheet2.Range("e" & n)
         Sheet1.Range("f7") = Sheet2.Range("f" & n)
         Exit For
Next n
sna
Re: vba not working
Post by sna »
thanks but i have another issue for adding new record.it is not working for duplicate adding
x = Sheet2.Range("a:a").Count
n = Sheet2.Range("a" & x).End(xlUp).Row + 1
For i = 1 To n
    If Sheet2.Range("a" & n) = Sheet2.Range("a" & i) Then
    Sheet2.Range("a" & n & "f:" & n).ClearContents
    MsgBox "ID dup"
tks
a.xlsb
(25.31 KiB) Downloaded 107 times
Re: vba not working
:D Adjust your code as below.
If Application.CountIfs(Sheet2.Range("a2:a" & n), _
    Sheet1.Range("c5").Value) Then
        MsgBox "ID dup"
For i = 1 To n
'    If Sheet2.Range("a" & n) = Sheet2.Range("a" & i) Then
'    Sheet2.Range("a" & n & "f:" & n).ClearContents
'    MsgBox "ID dup"
'    Exit Sub
'Else
    Sheet2.Range("b" & n) = Sheet1.Range("c7")
    Sheet2.Range("c" & n) = Sheet1.Range("c9")
    Sheet2.Range("d" & n) = Sheet1.Range("c11")
    Sheet2.Range("e" & n) = Sheet1.Range("f5")
    Sheet2.Range("f" & n) = Sheet1.Range("f7")
'    End If
sna
Re: vba not working
Post by sna »
thanks.it is so helpful
