sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Fri Dec 30, 2022 11:51 am
hi there
i need your help how write formula in M365 to get data from List of active loan base on criteria in column K meets loan product code 1016,1018
i need results to come up in sheet Recalculation FV Staff loans-22 in color cells
tks
by snasui » Fri Dec 30, 2022 12:19 pm
Please provide some example values and explain where the source and condition of it for other member easy to understand.
sna
by sna » Fri Dec 30, 2022 7:34 pm
Hi Admin
I want to get values from list of active loan to Recalculation FV Staff loans-22 if loan product code is 1016,1018 to the color cells .I give an example of data got from list of active loan if loan product code is 1016 or 1018.
Thanks
sna
by sna » Fri Dec 30, 2022 7:45 pm
LN NO.
LN000010-01
sna
by sna » Fri Dec 30, 2022 7:46 pm
Loan disbursement Bal O/S AIR
3,000.00 2,502.00 17.1257
sna
Start date Term
17-Jun-22 36
sna
Maturity date Product Code
25-Jun-25 1016
by snasui » Sat Dec 31, 2022 7:06 am
Try this formula in cell D6,
=FILTER('List of Active Loan'!B$11:B$151 ,ISNUMBER(MATCH('List of Active Loan'!$K$11:$K$151,{1016;1018},0)))
Press Enter > Copy this formula to the remaining columns and change B$11:B$151 to the range that you would like to get the result.
sna
by sna » Sat Dec 31, 2022 10:21 am
Wow ,thank you so much.happy new year coming soon .wish you good luck and happiness.
Best regards,
by snasui » Sat Dec 31, 2022 12:16 pm
