liveday
Posts: 286 Joined: Fri Mar 25, 2011 2:24 pm
Excel Ver: 2007
by liveday » Thu Oct 27, 2022 4:50 pm
ต้องการให้ค่าเป็น Blank กรณีไม่มีค่าตัวเลขให้รวมครับ จะต้องใช้สูตรอย่างไรบ้างครับ
by puriwutpokin » Thu Oct 27, 2022 5:39 pm
C4=IF(SUM(A4:B4),C$2+SUMIF(A$4:A4,">0")-SUMIF(B$4:B4,">0"),"") Copy down
หรือ
C4=(SUM(A4:B4)>1)*(C$2+SUMIF(A$4:A4,">0")-SUMIF(B$4:B4,">0"))
puriwutpokin on Thu Oct 27, 2022 5:45 pm, edited 3 times in total.
norkaz
Posts: 1748 Joined: Wed Jan 12, 2011 7:59 pm
Excel Ver: 2013,365
by norkaz » Thu Oct 27, 2022 5:39 pm
C4
=IF(A4+B4,$C$2+SUMPRODUCT($A$4:A4-$B$4:B4),"")
Copy ลงไป
Norkaz
