PT
sna
Excel Ver: Excel 365
PT
Post by sna »
Need Help!
I want to pivotize this dataset using Permission Type column and want an X as value for each column (which will populate after pivot option)
Issue is, in some cells the Permission Type column is having value as "PWP Interested Party" and "PWP Signatory" I don't want to pivot rows which has any one of these two values.
Instead of this I want "X" in Other, Tax Document and one more column is a row is having PWP Interested Party or PWP Signatory as value in its Permission Type Column.
a template is attached for your reference. I hope you guy will help me.
Thanks
Contact Sheet Summary Pratik xxxxx(1) (1).xlsx
(70.07 KiB) Downloaded 106 times
sna
Re: PT
Post by sna »
I need to pivot data sheet on the basis of O column in data sheet Which is Permission Type.I've already tried to do pivot and output result is shown on detail sheet
Re: PT
:D I guess you need custom format to show 'X' in value area (Column 'P' on sheet data) of each permission Type. See picture below and PivotTable report in Sheet1 in attached file.
(80.8 KiB) Downloaded 109 times
sna
Re: PT
Post by sna »
Thank you
