ขอสอบถามการปรับสูตร Countifs และ Sumifs ครับ
wisitsakbenz
Excel Ver: 2013
Post by wisitsakbenz »
เรียนอาจารย์
ขอสอบถามการปรับสูตร
Column "M" , "O" และ "R" คือสิ่งที่ต้องการครับ
Column "M"
"N4" สูตร =COUNTIFS(Data!$E:$E,A5,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A5,Data!$Q:$Q,"P")+COUNTIFS(Data!$E:$E,A6,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A6,Data!$Q:$Q,"P")+COUNTIFS(Data!$E:$E,A7,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A7,Data!$Q:$Q,"P")+COUNTIFS(Data!$E:$E,A8,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A8,Data!$Q:$Q,"P")+COUNTIFS(Data!$E:$E,A9,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A9,Data!$Q:$Q,"P")+COUNTIFS(Data!$E:$E,A10,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A10,Data!$Q:$Q,"P")& " / " &COUNTIF(Data!$E:$E,A5)+COUNTIF(Data!$E:$E,A6)+COUNTIF(Data!$E:$E,A7)+COUNTIF(Data!$E:$E,A8)+COUNTIF(Data!$E:$E,A9)+COUNTIF(Data!$E:$E,A10)
"N12" สูตร
=COUNTIFS(Data!$E:$E,A13,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A13,Data!$Q:$Q,"P")+COUNTIFS(Data!$E:$E,A14,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A14,Data!$Q:$Q,"P")+COUNTIFS(Data!$E:$E,A15,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A15,Data!$Q:$Q,"P")+COUNTIFS(Data!$E:$E,A16,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A16,Data!$Q:$Q,"P")&" / "&COUNTIF(Data!$E:$E,A13)+COUNTIF(Data!$E:$E,A14)+COUNTIF(Data!$E:$E,A15)+COUNTIF(Data!$E:$E,A16)
"N19" สูตร
=COUNTIFS(Data!$E:$E,A20,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A20,Data!$Q:$Q,"P")+COUNTIFS(Data!$E:$E,A21,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A21,Data!$Q:$Q,"P")+COUNTIFS(Data!$E:$E,A22,Data!$Q:$Q,"G")+COUNTIFS(Data!$E:$E,A22,Data!$Q:$Q,"P")&" / "&COUNTIF(Data!$E:$E,A20)+COUNTIF(Data!$E:$E,A21)+COUNTIF(Data!$E:$E,A22)
อาจารย์พอมีสูตรที่เขียนง่ายกว่านี้หรือไม่ครับ
Column "O"
34/53 = 64
21/36 = 58
อาจารย์พอมีสูตรหรือไม่ครับ
Column "Q"
"Q4" สูตร
=SUMIFS(Data!$N:$N,Data!$E:$E,Input!A5,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A5,Data!Q:Q,"P")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A6,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A6,Data!Q:Q,"P")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A7,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A7,Data!Q:Q,"P")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A8,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A8,Data!Q:Q,"P")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A9,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A9,Data!Q:Q,"P")++SUMIFS(Data!$N:$N,Data!$E:$E,Input!A10,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A10,Data!Q:Q,"P")
"Q12" สูตร
=SUMIFS(Data!$N:$N,Data!$E:$E,Input!A13,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A13,Data!Q:Q,"P")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A14,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A14,Data!Q:Q,"P")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A15,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A15,Data!Q:Q,"P")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A16,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A16,Data!Q:Q,"P")
"Q19" สูตร
=SUMIFS(Data!$N:$N,Data!$E:$E,Input!A20,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A20,Data!Q:Q,"P")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A21,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A21,Data!Q:Q,"P")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A22,Data!Q:Q,"G")+SUMIFS(Data!$N:$N,Data!$E:$E,Input!A22,Data!Q:Q,"P")
Column "R"
"R3" เอาค่าจากช่อง "Q3" โดย มีหน่วยเป็น MB (ล้านบาท)
6,619,723.71 = 6.62
4,867,723.71 = 4.87
Rowที่ 23 ในส่วนของ "Others"
C23 = จำนวนทั้งหมดที่ Dept ไม่ใช่ "WHC" ,"SUR" และ Code เป็น "G" , "P" / จำนวนทั้งหมดที่ Dept ไม่ใช่ "WHC" ,"SUR"
D23 = จำนวนทั้งหมดที่ Dept ไม่ใช่ "WHC" ,"SUR" และ Code เป็น "G" , "P" หารด้วย จำนวนทั้งหมดที่ Dept ไม่ใช่ "WHC" ,"SUR"
F23 = ผลรวมทั้งหมดที่ Dept ไม่ใช่ "WHC" ,"SUR" และ Code เป็น "G" , "P" / ผลรวมทั้งหมดที่ Dept ไม่ใช่ "WHC" ,"SUR"
ต้องเขียนสูตรอย่างไรครับ
Re: ขอสอบถามการปรับสูตร Countifs และ Sumifs ครับ
ตัวอย่าง N4=SUM(COUNTIFS(Data!$E:$E,A5:A10,Data!$Q:$Q,{"G","P"}))&" / "&SUM(COUNTIF(Data!$E:$E,A5:A10))
Q4=SUM(SUMIFS(Data!$N:$N,Data!$E:$E,A5:A10,Data!Q:Q,{"G","P"}))
R3=Q3/10^6
ส่วนตำแหน่งอื่นลองประยุกต์ดูครับ
wisitsakbenz
Excel Ver: 2013
เรียน อาจารย์ puriwutpokin
ได้ตาที่ต้องการแล้วครับ แต่ติดตรง
ต้องเขียนสูตรอย่างไรครับ ขอบคุณครับ
:D ตัวอย่างสูตรที่ C23 ตามด้านล่าง ลองประยุกต์ใช้ดูครับ
=COUNTA(Data!$E$2:$E$1000)-SUM(COUNTIFS(Data!$Q$2:$Q$1000,{"G","P"},Data!$D$2:$D$1000,{"WHC","SUR"}))&"/"&COUNTA(Data!$D$2:$D$1000)-SUM(COUNTIFS(Data!$D2:$D$1000,{"WHC","SUR"}))
wisitsakbenz
Excel Ver: 2013
เรียน อาจารย์
ลองปรับสูตรได้แล้วครับ ขอบคุณอาจารย์ทั้ง 2 คนมากครับ
