CF zero
sna
Excel Ver: Excel 365
CF zero
Post by sna »
Hi Dear
I need your help how to highlight cells for consecutive zero Without using helper column
I attach a sample for your reference
(With helper column)
Thank
Supachok
Excel Ver: 2013
Re: CF zero
Post by Supachok »
can we use
"conditional formatting"
Set criteria = 0
then define your display color
sna
Re: CF zero
Post by sna »
no I try this by my own before I post here
sna
Re: CF zero
Post by sna »
the solution you suggest would color all zeros,i mean consecutive zero by rows
Re: CF zero
:D Please try this conditional formatting procedure,
  1. Select A2:J8
  2. Use this formula in 'Format values where this formula is true' as picture below
    =IF(COLUMNS($A2:A2)=1,A2=0,OR(A2&OFFSET(A2,0,-1)="00",A2&B2="00"))
sna
Re: CF zero
Post by sna »
as great as always.thank you ☺️
