county
sna
Excel Ver: Excel 365
county
Post by sna »
Hi Dear
I need your help to count date in a range containing text, numbers and dates.
I can use count but it contains also numbers so it is not fine.
Best Wishes
sna
Re: county
Post by sna »
Here's the attached
eyepop99
Excel Ver: 365,2019,2010
Re: county
Post by eyepop99 »
Just use counta instead
C3 =COUNTA(A3:A14)
norkaz
Excel Ver: 2013,365
Re: county
Post by norkaz »
C3
=SUM(--IFERROR(YEAR(A2:A14)<>1900,0))
Ctrl + Shift + Enter
Norkaz
norkaz
Excel Ver: 2013,365
Re: county
Post by norkaz »
norkaz wrote: Tue Sep 14, 2021 5:35 pm ...
C3
Norkaz
Hi Guy,
The formula that I suggested above might not work properly once the other numbers are the same number of the DATE VALUES.
On the other hand, this problem can be solved by the other method related to Excel 365.
For the previous version, I don't think we cannot avoid the helper column, then do you prefer it?
Norkaz
sna
Re: county
Post by sna »
If possible no helper column even office 365
Re: county
:D Try with this formula,
=SUM(--(CELL("format",OFFSET(A2,ROW(A2:A14)-ROW(A2),0))="D1"))
sna
Re: county
Post by sna »
Hi
I try putting formula cell C1 but it's not working.it returns #Value
Re: county
:D The formula above for O365 only. If you found error in this version, please attach the updated file again.
sna
Re: county
Post by sna »
Ok.got it
I use office 2019,any formula can solve this?
norkaz
Excel Ver: 2013,365
Re: county
Post by norkaz »
B2
=CELL("format",A2)
C3
=COUNTIF(B2:B14,"D1")
Norkaz
Bo_ry
Excel Ver: MS 365
Re: county
Post by Bo_ry »
=SUM(--(CELL("format",INDIRECT(T(IF(1,"A"&ROW(A2:A14)))))="D1"))
Ctrl+Shift+Enter
=COUNTIFS(A2:A14,">10000")
sna
Re: county
Post by sna »
Thanks Bo_ry second formula works.
Once more if value in this column over 10000 this won't work fine.
Bo_ry
Excel Ver: MS 365
Re: county
Post by Bo_ry »
Both formulas work fine. please check the attached file.
After 369 posts, seem like you still don't know how to press Ctrl+Shift+Enter.
**Array formulas are not entered in the same way as 'standard' formulas. Instead of pressing just ENTER, you first hold down CTRL and SHIFT and only then press ENTER. If you've done it correctly, you'll notice Excel puts curly brackets {} around the formula (though do not attempt to manually insert these yourself).
https://support.microsoft.com/en-us/off ... f793412dfa
sna
Re: county
Post by sna »
I use office 2019 not M0365
