sna
Posts: 699 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Tue Sep 14, 2021 3:43 pm
Hi Dear
I need your help to count date in a range containing text, numbers and dates.
I can use count but it contains also numbers so it is not fine.
Best Wishes
sna
by sna » Tue Sep 14, 2021 3:44 pm
Here's the attached
eyepop99
Posts: 127 Joined: Fri Sep 01, 2017 3:19 pm
Excel Ver: 365,2019,2010
by eyepop99 » Tue Sep 14, 2021 3:55 pm
Just use counta instead
C3 =COUNTA(A3:A14)
norkaz
Posts: 1751 Joined: Wed Jan 12, 2011 7:59 pm
Excel Ver: 2013,365
by norkaz » Tue Sep 14, 2021 5:35 pm
C3
=SUM(--IFERROR(YEAR(A2:A14)<>1900,0))
Ctrl + Shift + Enter
Norkaz
norkaz
Excel Ver: 2013,365
by norkaz » Tue Sep 14, 2021 7:29 pm
norkaz wrote: Tue Sep 14, 2021 5:35 pm
C3
Norkaz
Hi Guy,
The formula that I suggested above might not work properly once the other numbers are the same number of the DATE VALUES.
On the other hand, this problem can be solved by the other method related to Excel 365.
For the previous version, I don't think we cannot avoid the helper column, then do you prefer it?
Norkaz
sna
by sna » Tue Sep 14, 2021 7:41 pm
If possible no helper column even office 365
Posts: 30941 Joined: Sun Jan 24, 2010 12:33 pm
by snasui » Tue Sep 14, 2021 8:17 pm
Try with this formula,
=SUM(--(CELL("format",OFFSET(A2,ROW(A2:A14)-ROW(A2),0))="D1"))
sna
by sna » Wed Sep 15, 2021 6:38 am
Hi
I try putting formula cell C1 but it's not working.it returns #Value
by snasui » Wed Sep 15, 2021 6:53 am
The formula above for O365 only. If you found error in this version, please attach the updated file again.
sna
by sna » Wed Sep 15, 2021 8:39 am
Ok.got it
I use office 2019,any formula can solve this?
norkaz
Excel Ver: 2013,365
by norkaz » Wed Sep 15, 2021 9:04 am
B2
=CELL("format",A2)
C3
=COUNTIF(B2:B14,"D1")
Norkaz
Bo_ry
Posts: 1245 Joined: Sun Aug 12, 2018 12:11 am
Excel Ver: MS 365
by Bo_ry » Wed Sep 15, 2021 1:19 pm
=SUM(--(CELL("format",INDIRECT(T(IF(1,"A"&ROW(A2:A14)))))="D1"))
Ctrl+Shift+Enter
=COUNTIFS(A2:A14,">10000")
sna
by sna » Wed Sep 15, 2021 1:59 pm
Thanks Bo_ry second formula works.
Once more if value in this column over 10000 this won't work fine.
Bo_ry
Excel Ver: MS 365
by Bo_ry » Wed Sep 15, 2021 2:34 pm
Both formulas work fine. please check the attached file.
After 369 posts, seem like you still don't know how to press Ctrl+Shift+Enter.
**Array formulas are not entered in the same way as 'standard' formulas. Instead of pressing just ENTER, you first hold down CTRL and SHIFT and only then press ENTER. If you've done it correctly, you'll notice Excel puts curly brackets {} around the formula (though do not attempt to manually insert these yourself).
https://support.microsoft.com/en-us/off ... f793412dfa
sna
by sna » Wed Sep 15, 2021 3:19 pm
I use office 2019 not M0365
