food cost
sna
Excel Ver: Excel 365
food cost
Post by sna »
Hi Dear,
I come up with an issue how to add values in single cells but data type not consistent like space and = sign.
I also attached and excel template with result on column b
Thanks
sna
Re: food cost
Post by sna »
Here's the attached
Re: food cost
:D You can use this formula for example text in your attached file.
=SUM(FILTERXML("<t><s>"&SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(A3," kg","kg"),"="," ")," ","</s><s>")&"</s></t>","//s"))
sna
Re: food cost
Post by sna »
Thank you 🙏
