issue reverse
sna
Excel Ver: Excel 365
issue reverse
Post by sna »
Hi Dear,
I have data layout a2:b6 I need to sort it by max numbers.i need a formula not built in feature.
I attached a sample with result in color cells
Thanks
Re: issue reverse
:D Try this,
  1. B12
    =LARGE($B$2:$B$6,ROWS(B$12:B12))
    Enter > Copy down
  2. A12
    =INDEX(A:A,AGGREGATE(15,6,ROW($A$2:$A$6)/($B$2:$B$6=B12),COUNTIF(B$12:B12,B12)))
    Enter > Copy down
sna
Re: issue reverse
Post by sna »
Thanks
but how we don't use helper column?
Re: issue reverse
:D You can do that with default feature or VBA not a formula.
sna
Re: issue reverse
Post by sna »
Ok thank you 🙏
Re: issue reverse
snasui wrote: Sun Mar 21, 2021 7:38 am :D You can do that with default feature or VBA not a formula.
:D The above quote means your result in the same place of the source.
If you need only one formula, can use this formula in A12.
=INDEX(A:A,MOD(AGGREGATE(14,6,$B$2:$B$6+ROW($B$2:$B$6)/1000,ROWS(A$12:A12)),1)*1000)
Enter > Copy to B12 then down.
sna
Re: issue reverse
Post by sna »
Thank you so much 🙏
