sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Sat Jan 02, 2021 11:19 am
Hi Dear
I need to extract text within brackets to multiple column.
I have listed result starts from column AC.
But the actual result I would need in column B onward.
I add a code below but work only one column
Thanks
Item Code.xlsx
(11.83 KiB) Downloaded 33 times
sna on Sat Jan 02, 2021 11:44 am, edited 1 time in total.
sna
by sna » Sat Jan 02, 2021 11:27 am
Sub Extract()
Dim Rng As Range,Dn As Range,Sp As Variant
Set Rng=Range("A2",Range("A"&Rows.Count).End(xlUp))
For Each Dn in Rng
Sp=Split(Dn.Value,"(")
If Ubound(Sp)>0 Then
Dn.offset(,1).Value=Left(Sp(1), Len(Sp(1)) - 1)
End if
Next
by snasui » Sat Jan 02, 2021 7:12 pm
Please attach file with code inside again for easy to be testing.
sna
by sna » Sat Jan 02, 2021 9:37 pm
Thanks for your prompt response.
Here's an attachment
Thanks
ect code.xlsm
(17.62 KiB) Downloaded 33 times
by snasui » Sat Jan 02, 2021 9:52 pm
The example code is below:
Sp = Split(Dn.Value, ")")
If UBound(Sp) > 0 Then
Dn.Offset(, 1).Value = Mid(Sp(0), 2)
Dn.Offset(, 2).Value = Sp(1)
sna
by sna » Mon Jan 04, 2021 10:03 pm
Hi Dear
It works for the first part another no work like in the columns highlight yellow
Thanks
ect code.xlsm
(17.68 KiB) Downloaded 30 times
by snasui » Mon Jan 04, 2021 10:51 pm
You can adjust code like this:
Set rng = Range("A2", Range("A" & Rows.Count).End(xlUp))
For Each Dn In rng
For i = LBound(Sp) To UBound(Sp) - 1
Dn.Offset(0, i + 1).Value = Split(Sp(i), "(")(1)
Next Dn
sna
by sna » Tue Jan 05, 2021 7:27 am
Thanks it worked flawlessly
